Hi Andrew,
Thank you VERY MUCH for your information. I got it.
I'm thinking of using the priority-based sheduling on a
dedicated embedded controller on the control network.
So, running EPICS as root should be OK.
(Acutually, we have already been running EPICS as root on
the controller...)
I surely look into epicsTreadPriorityTest to see how it
works.
Thank you again for your help.
Jun-ichi
----- Original Message -----
> Hi Jun-ichi,
> On Wednesday 22 April 2009 07:47:51 [email protected] wrote:
> > Thank you very much for the information.
> > Just say "YES"...
> > Is that all what I have to do?
> Well, almost. Linux only allows processes to use the pthreads real-
time
> priorities if the process is sufficiently privileged (because it's
easy to
> code a Denial of Service attack to bring down the OS if you have that
> privilege). There's probably a Capability (CAP_xx) that controls this,
but I
> don't know what it is. The easiest way to provide that is to run the
IOC as
> root, which I don't recommend on a general-use system for security
reasons
> but should be Ok on a dedicated machine.
> There is a test program called epicsThreadPriorityTest that you can
run from
> your base/src/libCom/test/O.<arch> directory which tells you whether
the
> threads are being scheduled strictly by priority or not, so you should
be
> able to use that to experiment.
> HTH,
> - Andrew
> > > > Dear All;
> > > > I've recently come to notice that the real-time performance of
Linux
> > > > kernel is incredibly improving (against my expectations).
> > > > http://www.osadl.org/Single-View.111+M5b96e97f67b.0.html
> > > > I'd like to know if the implementation of OSD-library is
implemented
> > in
> > > > such a manner that the kernel-level threads can reflect the
priority
> > > > given by the user to the scheduling of epicsThreads?
> > > > In other words, can I benefit from the improvement of Linux
kernel
> > > > without making any changes in EPICS source codes?
> > > in file base/configure/CONFIG_SITE
> > > change
> > > USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO
> > > to
> > > USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> > > Also you must start the IOC as root.
> > > Marty
> The best FOSS code is written to be read by other humans -- Harold
Welte
- Priorities of epicsThreads on Linux jun-ichi.odagiri
- Re: Priorities of epicsThreads on Linux Marty Kraimer
- Re: Priorities of epicsThreads on Linux jun-ichi.odagiri
- Re: Priorities of epicsThreads on Linux Andrew Johnson
Re: back propagating error states Andrew Johnson
XIA xMAP software Mark Rivers
<2009>
2025
2026
VisualDCT 2.6.1742 release Matej Sekoranja
<2009>
2025
2026
