1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM 3.1.4 + extensionsTop
To: Jack <[email protected]>
Cc: [email protected]
Date: Tue, 12 May 2009 10:03:27 -0700
Hi Mauro,
Thanks for the link.
It turns out I was being a noob. For Scientific Linux 4.5 the X11 directories are still in /usr/X11R6/lib instead of /usr/lib which is where extensionsTop is looking for them.
Simply modified the appropriate CONFIG file and it compiles fine.
Bertrand
On May 11, 2009, at 11:06 PM, Jack wrote:
we are using CentOS 5.2 (a rebuild of RHEL like SL) about the installation of MEDM have a look here: http://www.lnl.infn.it/~epics/WikiDumps/localhost/ epics_extensions.html
About the libXm the tech-talk helps: http://www.aps.anl.gov/epics/tech-talk/2007/msg01008.php
Hope this helps
Mauro.
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Tel. +39.049.8068558
Fax. +39.049.641925
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
Bertrand H.J. Biritz wrote:
Dear Tech-talk,
I was hoping to get a clarification on how to compile MEDM 3.1.4 on Scientific Linux 4.5.
I downloaded BASE 3.14.10 and then the extensionsTop_20070703 file. MEDM does not like this combination and has an error:
make[2]: *** No rule to make target `/usr/lib/libXm.a', needed by `medm'. Stop.
I then reverted to using extensionsConfig_20040406 and extensionsConfigure_20040406 files which worked.
Since the extensionsConfig and extensionsConfigure are no longer officially available I am guessing the above solution isn't the correct one.
What step(s) am I missing?
Bertrand
MEDM 3.1.4 + extensionsTop Bertrand H.J. Biritz
Re: MEDM 3.1.4 + extensionsTop Jack
Prev: XAL Workshop Tom Pelaia
Next: record linking question John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM 3.1.4 + extensionsTop Jack
Next: XAL Workshop Tom Pelaia
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
