You can get reliable performance by waiting for the database to
finish writing the first value before writing the second:
caput -c -w 3 masterC 1
caput -c -w 3 masterC 2
This will wait for completion, or for 3 seconds, whichever comes first,
after each put.
John Sinclair wrote:
My first message was incorrect - sorry.
I meant to say that the slave pvs update but the device does not. So, I
guess this is an EthernetIP device support question.
So, I will instead ask if anyone has seen this behavior?
John
The following is an attempt to control two slave pvs by a master pv via
a dfanout record.
The desired behavior is that wiggling masterC should cause both slave1C
and slave2C to follow.
record(ao, "masterC") {
field(DTYP, "SoftChannel")
field(OUT, "dfout PP")
field(SCAN, "Passive")
record(dfanout,"dfout") {
field(OUTA, "slave1C PP")
field(OUTB, "slave2C PP")
record(ao,"slave1C") {
field(SCAN,"Passive")
field(DTYP,"EtherIP")
field(OUT, "@cpu epics_outputs[0]")
record(ao,"slave2C") {
field(OUT, "@cpu epics_outputs[1]")
If I create a script as follows:
caput -t masterC 1
caput -t masterC 2
When executed, the result is that sometimes it works (i.e. slave1C and
slave2C have the final value 2) and sometimes it does not (slave1C and
slave2C have the final value 1).
Is the record linking in the above example flawed? If so, is there a way
to make this reliable?
TIA,
John Sinclair
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- Re: record linking question John Sinclair
- record linking question John Sinclair
Re: record linking question Kasemir, Kay
<2009>
2025
2026
<2009>
2025
2026
