1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Process ordering in CA and asyn
To: <[email protected]>
Date: Wed, 20 May 2009 11:23:01 +0100
I'm currently investigating a possible race condition in our motor
control software. In our motor controller driver we are setting a
parameter by using a BO record writing to an Asyn port.
Then we are setting a series of other parameters using the Asyn motor
device support layer (via the motor record), which is talking through
the same Asyn port as the BO record.
Then at the end we are setting again the BO record flag.
So my question is really about guaranteeing the process ordering of
these records, as well as making sure that the same ordering is
preserved in Asyn.
I know channel access has a sequence ID that the channel access server
uses to re-order CA events on the IOC, and process them in sequence
order number (is that right?).
On my client side, I do a series of ca_put()s, and call ca_pend_event()
after each one. But I understand that the CA client is not guaranteed to
service the event when calling ca_pend_event(). So is the CA sequence
number assigned to an event at the ca_put() stage, or the at the
ca_pend_event() stage?
Now on to Asyn... The device support layers for the BO and motor records
are connecting to the same Asyn port. Does the asynManager set up
different queues for each device support layer type? Or is it one queue
per port?
I am worried that if there are different queues for the motor records
and the BO record, then it is possible that the processing could be done
out of order in the scan task at this low level, even though processing
was initiated *in* order at the record level.
In the asyn documentation is does say that a thread handling a queue is
dedicated to a specific port, so I think that means that there is indeed
only one queue per port.
Cheers,
Matthew
DLS Controls
RE: Process ordering in CA and asyn Jeff Hill
RE: Process ordering in CA and asyn Mark Rivers
Prev: RE: Compiling problems building EPICS base 3.14.10 on cygwin-x86 Pacios Rodriguez Luis Orlando
Next: RE: Process ordering in CA and asyn Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
