1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Visibility PV problem in EDM
To: [email protected]
Date: Mon, 25 May 2009 16:25:45 +0530 (IST)
Hello,
I am using EDM 1-11-0z with base 3.14.9 on Ubuntu 8.10.
I have made two objects (static text) for On/Off status of a device, and
controlling their visibility by status. It seems that during 'execute',
the visibility PV doesn't update. The object only takes the initial value
of visibility PV, and the static text satisfying the visibility condition
for initial value is visible throughout.
Whereas, if I use a byte monitor (1 bit) for On/Off status, and use the
same PV name as the readback PV, then it updates properly.
It seems that the visibility of any monitor object, control object or
graphic object is not being updated.
I am using the following motif libraries.
libmotif-dev 2.2.3-2
libmotif3 2.2.3-2
motif-clients 2.2.3-2
Thanks and regards,
Prachi Chitnis
Accelerator Control Section
Raja Ramanna Centre for Advanced Technology,
Indore, India
Prev: get_ioint_info missing Hinko Kocevar
Next: RE: get_ioint_info missing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: get_ioint_info missing Hinko Kocevar
Next: First IOC_Overview example does not work. Pacios Rodriguez Luis Orlando
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
