1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: including one .stt file as a header in another
To: Patrick Thomas <[email protected]>
Cc: [email protected]
Date: Tue, 26 May 2009 07:48:59 -0400
Patrick Thomas wrote:
How would one go about including one .stt file as a header in another? I tried to do this with %%#include "....stt", but it does not seem to be finding the variables that are assigned to process variables in the included file. My makefile uses the following, where sncMyExample.stt is the sequencer code that I want to have include another .stt file.
ifneq ($(SNCSEQ),)
   # Build sncExample into h1_tcs_itmx_pwrSupport
   sncExample_SNCFLAGS += +r
   sncMyExample_SNCFLAGS = +m
   h1_tcs_itmx_pwr_DBD += sncExample.dbd
   h1_tcs_itmx_pwr_DBD += sncMyExample.dbd
   h1_tcs_itmx_pwrSupport_SRCS += sncExample.stt
   h1_tcs_itmx_pwrSupport_SRCS += sncMyExample.stt
   h1_tcs_itmx_pwrSupport_LIBS += seq pv
   h1_tcs_itmx_pwr_LIBS += seq pv
   # Build sncProgram as a standalone program
   PROD_HOST += sncProgram
   sncProgram_SNCFLAGS += +m
   sncProgram_SRCS += sncProgram.st
   sncProgram_LIBS += seq pv
   sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
Thank you,
Patrick
Patrick,
Just saw your post. It just sounds like your code needs to be c-preprocessed. In the case of the epics build system just rename you files .st instead of .stt. That should at least get you closer to the functionality you want. I'm not sure about how you would "include" a .st file however. Are you just trying to prevent assigning variable in a separate sequencer?
Wesley
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelerator Facility;Free Electron Laser
adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:FEL Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
including one .stt file as a header in another Patrick Thomas
Prev: Re: How to use process variable Ralph Lange
Next: Process Variable. z abdou
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: including one .stt file as a header in another Patrick Thomas
Next: get_ioint_info missing Hinko Kocevar
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
