1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Agilent E8257D Device Support?
To: "Gaul, Robert" <[email protected]>, <[email protected]>
Date: Fri, 29 May 2009 16:08:20 -0500
Hi Robert,
If you can’t find existing support then I would recommend streamDevice.  streamDevice is independent of the underlying transport mechanism (RS-232, GPIB, Ethernet).  It provides the device support for standard EPICS records, building the strings to send to the device and parsing the responses.  You don’t need to write any C code, just a protocol file.  The Agilent E8257D implements the “SCPI” protocol, which is a nice industry standard ASCII protocol for controlling devices.
From: [email protected] [mailto:[email protected]] On Behalf Of Gaul, Robert
Sent: Friday, May 29, 2009 2:35 PM
To: [email protected]
Subject: Agilent E8257D Device Support?
Hello,
I was wondering if anyone had device drivers directly for the Agilent E8257D microwave signal generator?
If drivers do not exist directly then I figure that you can connect it via GPIB to a LAN/GPIB gateway (Agilent E5810) and that this gateway has EPICS device drivers that include asynDriver and StreamDevice. My questions, if this is the route we have to go, is as follows:
-          Does anyone have support written for the 8257D using the gateway?
-          Would StreamDevice be needed? I want to say no because the 8257 is not RS-232 but I may be wrong in how I look at the architecture of everything
Any help from the community is helpful and I want to thank everyone in advance!
Robert Gaul III
Student Assistant
NSLS II
Agilent E8257D Device Support? Gaul, Robert
Prev: Agilent E8257D Device Support? Gaul, Robert
Next: Re: Agilent E8257D Device Support? Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
