1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem in epics installation
To: "K. Kiranbabu" <[email protected]>
Cc: [email protected]
Date: Tue, 02 Jun 2009 13:05:14 +0200
Hello,
this looks as if perl is either not installed or not found on your system.
Please make sure you carefully read the parts of the documentation that
talk about software requirements.
Good luck!
Ralph
On 02.06.2009 10:57 K. Kiranbabu wrote:
> Hello Guys,
> I am new bee to EPICS. I tried installing epics for windows. i used
> cygwin as the crosscompiler and epics .3.14.9 base. But when i tried
> the make command in the installation procedure, i got some errors
> saying certain files are missing . I am enclosing the screen shot of
> the error i got and the file i followed to install epcis.Please do
> find the below attached files. How to fix this , and  get epics
> installed sucessfully in the system.
> Awaiting for an early response from you,
> Thanks in advance,
> regards,
> K.S.KiranBabu,
> Research Scientist,
> SAMEER -CEM,
> Chennai.
Re: problem in epics installation Andrew Johnson
problem in epics installation K. Kiranbabu
Prev: Re: What is the maximum frequency for db scan? Dirk Zimoch
Next: RE: ezca libray Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: problem in epics installation K. Kiranbabu
Next: Re: problem in epics installation Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
