Steven M. Hartman wrote:
> Hinko Kocevar wrote:
>> Hello,
>> I'm trying to use subArray record type to display each array element at
>> index 0 .. n (n == 10; my case) in a separate PV.
> For your subArray records, use . . .
> field(MALM,"16") # number of elements of the waveform input
> field(NELM,"1") # number elements for desired subArray
> The subArray needs to allocate enough storage for MALM elements to hold
> the whole INP waveform, but you only want NELM elements for the subArray
> itself.
If I change subArray records the way you described it does not change
the output of the monitor to display only one value. The output is the
same as in the case I've described in previous mail (not desired to have
trailing zeros).
Best regards,
Hinko
Hinko Kocevar
Technical support engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
- Re: subArray processing J. Lewis Muir
- subArray processing Hinko Kocevar
- Re: subArray processing Steven M. Hartman
<2009>
2025
2026
<2009>
2025
2026
