Joe Sullivan wrote:
James Stevens wrote:
I would like to know if anyone in the Epics
community has written a GPIB device driver
for the Stanford Research Systems, Inc. Model
PS310 high voltage power supply...
http://www.teknetelectronics.com/Search.asp?p_ID=15873&pDo=DETAIL
Regards--Jim S.
Jim,
There is "unreleased" support for the 300 series in use
at the APS (XOR 8-ID). They are using the PS350. Let me
know if you want to try it.
The support is asyn/streams based.
I have found the GPIB interface to these devices a bit flacky and
required that the GPIB controller be in 'timeout mode' for it to be
reliable. The result was a very slow (2 times sec) update rate.
SRS insisted that there is not a know problem with the unit (shrug).
Joe
RE: Update rate...2 Hz was a typo...each message takes 300ms, so a full
update (3
messages) takes a little short of a second.
- Stanford Research PS310 Power Supply James Stevens
- Re: Stanford Research PS310 Power Supply Joe Sullivan
RE: EDM Properties Windows Kevin Anderson
<2009>
2025
2026
misleading error message from dbLoadRecords in Epics 3.14.8.2 Goetz Pfeiffer
<2009>
2025
2026
