1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Fwd: RE: PV gateway]
Date: Thu, 11 Jun 2009 19:03:33 -0400
Anyone have insight about the gateway and non-default CA ports?
-ps
-------- Original Message --------
Subject: RE: PV gateway
Date: Thu, 11 Jun 2009 14:50:25 -0700
To: Paul Sichta <[email protected]>
Interesting, when I try the default ports, the gateway works. My question is that
1) do I have to use the default ports for gateway?
2) If I can use other ports, why do 5080 & 5081 not work? What is so special about these two ports?
Jingchen
-----Original Message-----
Sent: Thursday, June 11, 2009 12:41 PM
To: 'Paul Sichta'
Thanks Paul. Yes, we has a firewall between two private subnets, but it is configured to allow all traffics and opened up to all ports. Like any other gateways we had before, we didn't use the default port.
Jingchen
Sent: Thursday, June 11, 2009 12:29 PM
To: Zhou, Jingchen
Subject: Re: PV gateway
Jingchen,
Have you a firewall enabled?  EPICS uses ports 5064 & 5065 by default.
It looks like your port is 5081 .... I'm not sure if that is tandard for the firewall but I don't think so.
-Paul Sichta
PPPL
On 06/11/2009 03:09 PM Zhou, Jingchen wrote:
I have set up a PV gateway, and the gateway is built against EPICS Base R3.14.10.  When I brought up the gateway, I saw the following errors scrolling up in the log:
../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon (send to "172.21.40.20:5081") error was "Connection refused"
Jun 11 11:44:57 !!! Errlog message received (message is above)
The gateway was up, but not functional at all, I checked the gateway diagnostic panel, nothing was connected, including the gateway's internal PVs.
Any idea?
Jingchen
Prev: problem about environment variables under vxWorks-6.6 Andrew Johnson
Next: RE: problem about environment variables under vxWorks-6.6 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: FW: PV gateway Jeff Hill
Next: help for developing a simple application on EPICS D.Chinnadurai
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
