1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "A32 RegisterAddress error" about Hytec8401
To: liuping <[email protected]>
Cc: [email protected]
Date: Thu, 25 Jun 2009 09:33:47 -0400
Hi Liu,
you create it along your build of vxWorks image.
gmake bootrom I think, but check their documentation.
Matthieu
On 06/25/09 04:19, liuping wrote:
> Hi all,
> Thank you for your reply! The problem was done.
> One guy gave me a bootrom.bin file, and I flash it into mvme5500 Boot
> Rom. Finally the hytec8401 works well. But really I don’t know the
> secret of bootrom.bin file.
> Best regards,
> LIU Ping
> *From:* [email protected]
> [mailto:[email protected]]
> *Send:* 2009.6.16日 11:40
> *to:* [email protected]
> *subject:* "A32 RegisterAddress error" about Hytec8401
> Hi,
> As a fresh man, I need your help. The hardware is Hytec8002 and
> hytec8401. Hytec8401ip driver came from Diamond website. I made my own
> application project with EPICS V3.14.8.2 and VxWorks V5.5.1. The codes
> compiling is no error but some warnings. When downloaded to
> VME(mvme5500), there are some error message as below:
> ## Load record instances
> dbLoadRecords("db/8401.db")
> value = 0 = 0x0
> # slot int options
> IPCAC6 = ipacEXTAddCarrier(&EXTHy8002, "6 2 10")
> Id: drvHy8002.c,v 1.10 2001/11/20 12:21:42 wscott Exp
> 8002 initialise 6 2 10
> PROM manufacturer ID: 0x8003 (HyTec Electronics Ltd., Reading, UK)
> PROM model #: 0x8002, board rev. 0x03
> PROM Xilinx rev.: 0x03, 0x00, 0x07
> PROM Serial #: 0x00 0x00 0x00 0x00 0x05 0xce
> drvHy8002filename="../.: A32 RegisterAddress error
> (status=./..34144267/src/libCom/)osi/devLib.c" line vmeslot number=282
> 6, ipslot unable to m0ap address VME A32 at address
> base=0X11800000800000 size =
> 0X100000
> 0xIP memo1ef31290ry register (error!
> tShell): drvHy8002ipacAddCarrie: Cannot register A32 device at r:
> 1800000Hytec VICB8002. Error is driver retur209000bned an error.
> new symbol "IPCAC6" added to symbol table.
> IPCAC6 = 0x1ee87ff0: value = -1 = 0xffffffff
> #-------- 8401 (Analogue
> Input)------------------------------------------------
> # card, slot, ipsl, intl, inte, aity, clks, clkr, inhi, samp, spac, trig
> Hy8401ipConfigure ( 60, IPCAC6, A, 0, 0, 0, 0, 15, 0, 1, 1, 0)
> $Id: drvHy8401ip.c,v 1.8 2005/10/27 09:07:01 mga83 Exp $
> Hy8401ipConfigure: card 60, VME slot -1, IP slot 0,
> vector 0, itr state 0, ai type 0,
> clock src 0, clock rate 15, inhibit 0,
> samples 1, spacing 1, trigger 0
> value = 0 = 0x0
> shellPromptSet "1054-Test> "
> value = 2178076 = 0x213c1c = shellHistSize + 0x4
> iocInit()
> Starting iocInit
> ### EPICS IOC CORE built on Jul 16 2008
> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> ***drvIpac version extended for Hot Swap
> ***$Id: drvIpac.c,v 1.3 2004/05/17 10:57:14 pho Exp $
> SPAWNING HOTSWAP SCAN TASK
> 0x1ef31290 (tShell): drvHy8401ip: Cannot register Hy8401ip A16
> device.iocInit: All initialization complete
> value = 0 = 0x0
> Done executing startup script
> /home/blctrl/hytec_ADC/iocBoot/iocHy8401ADC/st.cmd
> 1054-Test>
> I check out the error “A32 RegisterAddress error” come from the line 667
> of drvHy8002.c file
> How to correct? Thanks a lot!
> LIU Ping
> Beamline Control Group
> Shanghai Synchrotron Radiation Facility
> Shanghai Institute of Applied Physics
> Chinese Academy of Sciences
> Zhangheng Rd 239,Pudong Dist.,
> Shanghai 201204
> China
> Tel:+86-21-33933237
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
re: "A32 RegisterAddress error" about Hytec8401 liuping
Prev: re: "A32 RegisterAddress error" about Hytec8401 liuping
Next: Re: Troubles building jca.jar J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Controlling multiple CAN busses Elliott Wolin
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
