Two questions:
1) Does the asyn record block when reading until the requested amount of
bytes (NRRD) is available in the serial fifo buffer, or does it only
block until 1 byte is available (like the c read function), or not at all?
2) Is there a way to check that it has gotten all the requested bytes
into the record before doing a caget on the BINP field to retrieve them?
Thank you for your time,
Patrick
- Re: reading with the asyn record Eric Norum
Re: choosing snmp version Euan Troup
RE: choosing snmp version Rees, NP (Nick)
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
