1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: File Chooser
To: "Szalata, Zenon M." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 07 Jul 2009 17:39:13 -0400
EDM displays a file chooser window if it cannot locate the specified file when EDM is first executed.  All users are familiar with that and perhaps you can find a way to make use of it so the path used puts you in the correct directory.  On Linux systems there is often in the distribution a collection of widgets that are part of a utility 'zenity' which is generally useful when writing shell scripts.  These are not elegant solutions, but I have used them in the past when I could not find a better way.
John
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Tuesday, July 07, 2009 3:54 PM
To: [email protected]
Subject: File Chooser
 I have written a soft IOC which reads data from a disk file and places values read into EPICS records.  A few EDM screens are used to display the data...
All of this works fine.
There a number of disk files to choose from.
I have implemented a simple way to specify the file name using a waveform record and a text control.  This scheme is very difficult to use.
I think that EDM does not provide a file name chooser dialog.  Is that true?
If so, has anyone implemented some EDM widget which could be used to choose a file name from existing files on a disk drive?
Thanks in advance,
Zen
choosing snmp version Pierrick Hanlet
File Chooser Szalata, Zenon M.
Prev: Proposed change to ASYN lockPort() Eric Norum
Next: Re: EDM X-Y Graph zoom shrinks with its zoom? John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: File Chooser Szalata, Zenon M.
Next: Re: File Chooser John Sinclair
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
