1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: When an external device does not provide termination on TCP ASCIIstream replies
To: "Dirk Zimoch" <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Wed, 15 Jul 2009 14:02:48 -0700
Hi Dirk,
Thanks for your reply.
> Have you tried to set ReadTimeout=0 ?
Yes, setting ReadTimeout to 0 works but I haven't yet tested it on a busy network.  I fear that if I set ReadTimeout to 0 and the network is a little slow between the time I send the request and the time the reply is ready, the read will return an error.
> Can you give an example of such a message? Any constant string at the end can be
> used as a terminator, not just CR or LF.
I send "MEAS:VOLT?;"  and I receive "00.009" with no terminator (see below for asyn output).  This is an example of a fixed-length reply where I can use MaxInput of 6 and the reply read will not timeout.  But not all replies are fixed length like this one.
2009/07/15 13:45:26.642 118-PSD5 flush
2009/07/15 13:45:26.642 134.79.35.216:8003 flush
2009/07/15 13:45:26.642 134.79.35.216:8003 write.
2009/07/15 13:45:26.642 134.79.35.216:8003 write 11
MEAS:VOLT?;
2009/07/15 13:45:26.642 118-PSD5 addr -1 queueRequest priority 0 from lockHolder
2009/07/15 13:45:26.642 118-PSD5 schedule queueRequest timeout
2009/07/15 13:45:26.642 118-PSD5 callback
2009/07/15 13:45:26.642 134.79.35.216:8003 read.
2009/07/15 13:45:26.727 134.79.35.216:8003 read 6
00.009
2009/07/15 13:45:26.727 118-PSD5 read
00.009
2009/07/15 13:45:26.727 134.79.35.216:8003 read.
Note the last "read" above is not necessary but is done anyway since there's no terminator.
Thank you,
Stephanie
> Allison, Stephanie wrote:
> > Hi Mark,
> > Thanks for your reply.  I'm currently using stream version 2.2 and asyn version 4.9 on
> epics base 3.14.8.2.  I'm unable to get stream to work without timeout when the
> InTerminator is set to "" (meaning no terminator) and MaxInput=0.  Stream/asyn always
> waits ReadTimeout even though it has received the reply (it just doesn't know it has the
> *complete* reply).   If I set maxInput to a large number, then it also waits ReadTimeout
> waiting for extra input it'll never receive.
> > I would really like to use stream instead of writing my own support on top of asyn just for
> this case.  Does anybody know how can I set up stream so that the InTerminator is "",
> maxInput is 100, but there is no need to wait for anything more after something...anything >
> 0 chars is received?   I still want to use a reasonable ReadTimeout for when things slow
> down a bit on the network.  Maybe I can use devGpib for this case, though stream would be
> better.
> > Thank you,
> > Stephanie
> >> -----Original Message-----
> >> From: Mark Rivers [mailto:[email protected]]
> >> Sent: Tuesday, July 14, 2009 10:16 AM
> >> To: Allison, Stephanie; Epics Questions
> ASCIIstream
> >> replies
> >> Hi Stephanie,
> >> I think you should be fine.  Many TCP devices don't sent terminators,
> >> unlike their serial counterparts.  In your st.cmd file you just don't
> >> define an input or output EOS for that driver, and you don't put a
> >> terminator in your protocol file.  The TCP driver does not loop waiting
> >> for maxChars, it just reads the message.  TCP delivers "complete"
> >> messages, so you will get the complete response, not just a partial
> >> response.
> >> Mark
> >> From: [email protected]
> >> [mailto:[email protected]] On Behalf Of Allison, Stephanie
> >> Sent: Tuesday, July 14, 2009 11:58 AM
> >> To: Epics Questions
> >> Subject: When an external device does not provide termination on TCP
> >> ASCIIstream replies
> >> Hello,
> >> We're testing a Genesys power supply (provided by Lambda-TDK) to which
> >> the vendor has added a TCP interface (I believe specifically by request
> >> of EPICS sites).  Burkhard Kolb at GSI provided me the protocol file for
> >> stream/asyn support for this type of device (thanks!).  However, the
> >> firmware has changed recently and one change is to remove the terminator
> >> from the reply strings.  Some replies are fixed-length so I can change
> >> the protocol file for these (to use maxInput).  However some replies are
> >> not fixed-length and I need to find support for those - I do not want to
> >> rely on a timeout to know that the reply is finished.  The vendor has
> >> suggested that (1) I assume the reply will never get fragmented and just
> >> allocate 100 bytes and take whatever I get and (2) block on the receive
> >> (which is not an option for an IOC).
> >> Does anybody have experience with such devices (TCP ASCII SCPI commands
> >> that have no reply terminators and no fixed-length reply strings) and
> >> can recommend a solution?
> >> Thank you,
> >> Stephanie Allison
> >> SLAC National Accelerator Lab
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Re: When an external device does not provide termination on TCP ASCIIstream replies Dirk Zimoch
When an external device does not provide termination on TCP ASCII stream replies Allison, Stephanie
RE: When an external device does not provide termination on TCP ASCIIstream replies Mark Rivers
RE: When an external device does not provide termination on TCP ASCIIstream replies Allison, Stephanie
Prev: RE: uptodate version of modtcp? So, Sung-Leung
Next: Re: VXI11 connect failed Kazuro FURUKAWA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: When an external device does not provide termination on TCP ASCIIstream replies Dirk Zimoch
Next: Re: When an external device does not provide termination on TCP ASCIIstream replies Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
