1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VXI11 connect failed
To: <[email protected]>
Date: Wed, 15 Jul 2009 17:49:15 +0800
Hello, everyone
I am a beginner to use EPICS system.
I want to connect to an instrument SL1000 via VXI11 mode.
But unluckily some error happened.
My PC environment:
OS: CentOS5.3
EPICS_BASE: base-3.14.10
asynDriver: asyn-4.11
instrument: sl1000-1.1
So someone could tell why connect is failed?
And what is the problem with my epics project?
Thanks very much!
Error message is followed:
[root@luoxizhi-01 iocscope]# ../../bin/linux-x86/scope st.cmd
#!../../bin/solaris-sparc/scopetest
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocscope")
epicsEnvSet("TOP","/opt/epics/modules/sl1000-1.1")
epicsEnvSet("SUPPORT","/opt/epics")
epicsEnvSet("ASYN","/opt/epics/modules/asyn")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
< envParams
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 5000000
# Site-specific configuration
epicsEnvSet(ETHER1, "10.0.158.39")  # Choose scope ethernet address
epicsEnvSet(SCOPE1, "scope1:")        # Choose scope name
#epicsEnvSet(ETHER2, "192.168.21.55")  # Choose scope ethernet address
#epicsEnvSet(SCOPE2, "scope2:")        # Choose scope name
# Ensure that we can transfer a complete waveform
epicsEnvSet(EPICS_CA_MAX_ARRAY_BYTES, 5000000)
cd /opt/epics/modules/sl1000-1.1
dbLoadDatabase("dbd/scope.dbd")
scope_registerRecordDeviceDriver(pdbbase)
## This is the main db.
dbLoadRecords("db/SL1000.db","scope=scope1:,L=0,A=0,ASG=TEST1,Name=YOKOG
AWA SL1000-1,WF_NELM=10000,DISPWF_NELM=1000,SRQ_EVNT=101")
#dbLoadRecords("db/SL1000.db","scope=$(SCOPE2),L=0,A=0,ASG=TEST2,Name=YO
KOGAWA SL1000-2,WF_NELM=10000,DISPWF_NELM=1000,SRQ_EVNT=102")
## Set up IOC/hardware links -- Direct network connection
vxi11Configure("L0", "10.0.158.39", 0, 0.0, "inst0", 0)
#vxi11Configure("L1", "$(ETHER2)", 0, 0.0, "inst0", 0)
## Start IOC
cd /opt/epics/modules/sl1000-1.1/iocBoot/iocscope
iocInit()
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Jul 15 2009
2009/07/16 01:37:17.577 L0 vxi11 clientCall errno Success clnt_stat 5
2009/07/16 01:37:17.577 L0 vxiCreateIrqChannel (create_intr_chan): RPC:
Timed out
2009/07/16 01:37:17.577 L0 Warning -- SRQ not operational.
Segmentation fault
Re: VXI11 connect failed Kazuro FURUKAWA
Prev: Re: When an external device does not provide termination on TCP ASCIIstream replies Burkhard Kolb
Next: Re: CAEN SY127 and SY527 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Fwd: Re: When an external device does not provide termination on TCP ASCIIstream replies] Burkhard Kolb
Next: Re: VXI11 connect failed Kazuro FURUKAWA
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
