1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Escaped strings from fullPathName.pl
To: "Pedersen, UK (Ulrik)" <[email protected]>, <[email protected]>
Date: Thu, 16 Jul 2009 10:00:46 -0500
OK, my version of perl (from Cygwin) does not have this problem:
$ perl
/corvette/usr/local/epics/base-3.14.10/bin/win32-x86/fullPathName.pl ..
j:/epics/devel/dxp
$ perl
j:/epics/devel
-----Original Message-----
From: Pedersen, UK (Ulrik) [mailto:[email protected]]
Sent: Thursday, July 16, 2009 9:57 AM
To: Mark Rivers; [email protected]
 Hi Mark,
It really is quite strange. I think it has something to do with the perl
version I'm using or perhaps my environment(???)
On my machine fullPathName.pl always returns paths with backward
slashes:
W:\work\epics\R3.14.10\base>fullPathName.pl ..\..
W:\work\epics
W:\work\epics\R3.14.10\base>fullPathName.pl ../..
W:\work\epics
W:\work\epics\R3.14.10\base>fullPathName.pl ../../R3.14.10
C:\Documents and Settings\up45\Desktop>fullPathName.pl ../../up45/
C:\Documents and Settings\up45\Desktop>fullPathName.pl "c:/mingw/bin"
C:\mingw\bin
I have always used ActiveState ActivePerl version 5.10.0.1003 and I
didn't get this behaviour on my previous PC (which of course I have no
longer available to mess around with).
For now I think I will just modify the src/softIoc/Makefile to convert
the string to forward slashes.
If anyone out there has a suggestion to fix it or explanation, please do
let me know.
Cheers,
Ulrik
Sent: 16 July 2009 14:51
To: Pedersen, UK (Ulrik); [email protected]
Ulrik,
That is not happening for me with R3.13.10 on Windows.  Here is the
output I get:
cl /nologo /EHsc /GR -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0   /RTCsu /Zi    /W3 /w44355
DEPICS_BASE=h:/epics/base-3.14.10    /MTd -DEPICS_DLL_NO   -I.
-I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I..\\..\\..\\include        /Tp ..\\softMain.cpp
softMain.cpp
Note that the -D for EPICS_BASE has forward slashes.
I am running Visual Studio 2005, Cygwin perl (v5.10.0).  I believe the
version of make is an old version from Cygwin before they broke it.
[mailto:[email protected]] On Behalf Of Pedersen, UK (Ulrik)
Sent: Thursday, July 16, 2009 5:19 AM
To: [email protected]
Subject: Escaped strings from fullPathName.pl
Hello,
In a recent attempt to build base R3.14.10 on Windows I have come across
a build problem in src\softIoc\. The Makefile uses fullPathName.pl to
create an EPICS_BASE variable which is the full path to the base
installation. This is passed to the build of the softMain.cpp with the
-D flag and used in the code to create a C string.
Unfortunately fullPathName.pl creates a string with backslashes in it
(when expanding the relative path ../../..). The compiler falls over
when it get to compile this string with backslashes (see build output
below).
Strangely enough I have not come across this problem before when I have
build base R3.14.10 under Windows - but I'm now using a new PC with a
fresh installation of the build tools (Same versions as on my old PC
though: Visual Studio .NET 2003, MinGW 5.1.4 for make and perl
(ActiveState) 5.10.0.1003)
When I fun fullPathName.pl manually it always seems to produce paths
will backslashes on my PC.
I suppose a fix can be done either by adding a flag to fullPathName.pl
to force creation of paths with forward slashes - or alternatively force
the src/softIoc/Makefile to always substitute backward with forward
slashes in the string contained in the EPICS_BASE (local) variable(???)
Here is the output of the build of src/softIoc/softMain.cpp:
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0   /Ox /GL   /W3 /w44355
-DEPICS_BASE=W:\work\up45\R3.14.10\base   /MT -DEPICS_DLL_NO   -I
. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32
Main.cpp
softMain.cpp
..\softMain.cpp(81) : warning C4129: 'u' : unrecognized character escape
sequence
..\softMain.cpp(81) : error C3847: wrong symbol in universal character;
must use hex digits
..\softMain.cpp(81) : warning C4129: 'w' : unrecognized character escape
sequence
..\softMain.cpp(81) : warning C4129: 'R' : unrecognized character escape
sequence
..\softMain.cpp(82) : warning C4129: 'u' : unrecognized character escape
sequence
..\softMain.cpp(82) : error C3847: wrong symbol in universal character;
must use hex digits
..\softMain.cpp(82) : warning C4129: 'w' : unrecognized character escape
sequence
..\softMain.cpp(82) : warning C4129: 'R' : unrecognized character escape
sequence
mingw32-make[1]: *** [softMain.obj] Error 2
mingw32-make[1]: Leaving directory
`W:/work/up45/R3.14.10/base/src/softIoc/O.win32-x86'
mingw32-make: *** [install.win32-x86] Error 2
Has anyone by any chance come across the same problem?
Cheers,
Ulrik
  Ulrik Pedersen               phone: +44(0)1235-778580
  Software Engineer            email: [email protected]
      Diamond Light Source Ltd.
      Rutherford Appleton Laboratory,
      Chilton, Didcot
      Oxfordshire OX11 0DE
Scanned by iCritical.
Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
RE: Escaped strings from fullPathName.pl Mark Rivers
RE: Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
Prev: RE: Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
Next: Re: When an external device does not provide termination on TCP ASCIIstream replies Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Escaped strings from fullPathName.pl Rees, NP (Nick)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
