1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to change baudrate to 921600 in asyn?
To: tech-talk <[email protected]>
Date: Tue, 21 Jul 2009 18:57:01 +0200
Hi again Christof,
I did not read your mail properly. You don't use the serial port of your
computer but the USB port, right?
I assume the USB device registers itself as a "serial interface" like a
USB/RS232 interface? So a /dev/tty... (probably /dev/ttyUSB0) appears in your
system? If so try to set the baudrate from the Linux command line:
stty -F /dev/ttyUSB0 921600
If that works, it should be possible to start the ioc afterwards. If not, the
driver for that device does not support this baudrate.
Dirk
Christof Motzko wrote:
I am trying to communicate with the I-7565 USB/CAN Converter with StreamDevice, which can be used as local serial device. A baud rate of 921600 is necessary for the Converter, but I can't configure asyn to this baud rate. Can anybody tell me how I can change the baud rate to 921600?
Thanks
Christof
Christof Motzko
Institut f. Experimentalphysik I
Ruhr-Universitaet-Bochum
Universitaetsstr. 150
D-44780 Bochum
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
How to change baudrate to 921600 in asyn? Christof Motzko
Prev: Re: cainfo does display host info Ernest L. Williams Jr.
Next: Re: cainfo does display host info Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to change baudrate to 921600 in asyn? Dirk Zimoch
Next: cainfo does display host info Carl Schumann
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
