Hello,
This mail is in reference to my previous mail. While I previously said
that GetWFC1.VAL is showing correct data, I saw some strange behavior. The
query to the scope (C1:WAVEFORM? DAT1) replies back integers (127 to -128)
which show relative positon of a point to x axis. Now whenever I get a y=0
point, all the values after that disappear in the GetWFC1.VAL array.
Follows my device support read_wf() function:
static long read_wf(pwf)
struct waveformRecord *pwf;
struct vmeio *pvmeio;
char ip_address[50];
int sockfd;
char outbuf[MAX_O_ST];
char inbuf[MAX_I_ST];
sprintf(ip_address, OUR_SCOPE_IP);
sockfd=LECROY_TCP_connect(ip_address, MAX_TCP_CONNECT);
if (sockfd<0)
errlogPrintf("\nCould not connect to the scope on IP: %s\n",ip_address);
pwf->udf = FALSE;
pvmeio = (struct vmeio *)&(pwf->inp.value);
strcpy(outbuf,&(*(pvmeio->parm)));
if(pvmeio->card)
{LECROY_TCP_write(sockfd, outbuf);}
if(pvmeio->signal)
{LECROY_TCP_read(sockfd, inbuf, sizeof(inbuf), MAX_TCP_READ);}
pwf->bptr = inbuf;
pwf->nord = strlen(inbuf);
LECROY_TCP_disconnect(sockfd);
return(0);
Please help me out...
Thanx n regards
Prachi Chitnis
Scientific Officer 'C'
Raja Ramanna Centre for Advanced Technology,Indore
India
| Hello,
| My setup consists of a LeCroy scope that is interfaced to an Ubuntu 8.10
| machine on Ethernet.
| I could not use Asyn to communicate with this scope, so I wrote device
| support for it. My db file is as follows:
| record(waveform, GetWFC1) {
| field(SCAN, "1 second")
| field(PINI, "NO")
| field(DTYP, "LeCroy WaveSurfer")
| field(INP, "#C1 S1 @C1:WAVEFORM? DAT1\n")
| field(NELM, "1000")
| field(FTVL, "CHAR")
| record(waveform, C1a) {
| field(PINI, "NO")
| field(DTYP, "Soft Channel")
| field(INP, "GetWFC1 CA")
| field(NELM, "1000")
| field(FTVL, "CHAR")
| I am using the VME_IO for input link for "LeCroy Wavesurfer" device
| support. Card = (1,0) denotes (write, no write) to device, Signal = (1,0)
| denotes (read, no read) from the device and the parm denotes the command
| to be written to the device. The GetWFC1.VAL field is showing correct data
| & is updating properly.
| My problems are:
| 1) When I keep C1a.INP as PP, I dont get any data into it.
| 2) When I keep C1a.INP as CA (also CP), and monitor this record, I get
| the data into VAL field, the timestamp updates but the data doesn't
| update.
| 3) When I morph C1a to subarray record, with same fields and MALM set to
| 1000, the the same prob as 2) occurs
| 4) I also set the PHAS fields of both records as 0 and 1(resp.), but that
| too didn't work.
| 5) When I group these two records, then nor PP neither CA input link is
| able to fetch data into the VAL field of group:C1a record.
| 6) I also tried to make the scan rate of C1a faster than GetWFC1, but
| that didn't help.
| Please suggest some solution.
| Thanx in advance...
| Prachi Chitnis
| Raja Ramanna Centre for Advanced Technology, Indore
| India
- Re: --more-- Waveform record updating problem Burkhard Kolb
- Waveform record updating problem Prachi Chitnis
Re: Stream Device I/O Intr bugs, ongoing Dirk Zimoch
<2009>
2025
2026
<2009>
2025
2026
