Jeff,
Do you know if LabView 2009 with CA support will work on Linux as well
as Windows? I would be vert interested in if it works with Linux (OK,
I am interested in how well it works with Windows).
On Wed, Jul 22, 2009 at 12:16 AM, Jeffrey Holt<[email protected]> wrote:
> The newest version of LabVIEW (2009, due out next month) supposedly has full
> support for CA through the use of their "EPICS I/O Server" which will load
> an EPIC .db file and create a new set variables. These can then be tied
> directly into LabVIEW shared variables which are extremely easy to use.
> This architecture has actually been available in LV applications running on
> a PC for a couple of versions (I think). I'm pretty good at LV (but really
> bad in EPICS) and have successfully created this reasonably direct
> connection with LV version 8.6 and EPICS 3.14.
> LabVIEW 2009 supposedly now supports the same thing on Real-Time
> controllers. I am (this week) attempting to run an advance LV 2009 copy in
> the manner described. I will be very happy if this works...
> Cheers,
> -Jeff
> On 7/20/09, Wesley Moore <[email protected]> wrote:
>> tech-talkers,
>> Yes I know this has been done, but what's the difficulty in setting this
>> up? What is the preferred method and has the experience been good or bad?
>> It seems like the decision to support this is based on extent of it's
>> usage.
>> Thanks for any comments,
>> Wesley
- Re: labview w/ CA Andy Foster
- labview w/ CA Wesley Moore
- Re: labview w/ CA Jeffrey Holt
RE: checking for change in value in device support function Mark Rivers
<2009>
2025
2026
Re: labview w/ CA Wesley Moore
<2009>
2025
2026
