1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Archiver over long timespans
Date: Sat, 01 Aug 2009 06:02:47 -0500
I'm running 3.14.10 with v2.9.2 Channel Archiver on linux Centos.
I'm reading some environmental variables (temperatures, humidity,
etc.) at the rate of once per hour.  However, though the archiver does
not stop running, when I look at the output with ArchiveExport, I never
see more than a hand full of readings.  (I've not gotten the viewer
operational yet, so it may be a problem in how I'm using ArchiveExport).
Has anyone seen this before?  Any suggestions as to how I might
log slowly?  Might I not be setting the global variables in my engineconfig
file correctly?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Prev: Re: Escaped strings from fullPathName.pl Andrew Johnson
Next: EDM: Text Monitor Widget Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC crash when asyn traceflow turned on Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
