1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAJ questions
Cc: [email protected]
Date: Wed, 5 Aug 2009 14:11:58 +0200
HI,
I have another question about CAJ, relating to the property
"max_array_bytes".
I am not setting the "max_array_bytes" property in a properties file or
in my application.  When I call context.printInfo in my running
application I get the following:
context.printfInfo  ****************************
CLASS : com.cosylab.epics.caj.CAJContext
ADDR_LIST : localhost 164.54.160.255
AUTO_ADDR_LIST : false
CONNECTION_TIMEOUT : 30.0
BEACON_PERIOD : 15.0
REPEATER_PORT : 5065
SERVER_PORT : 5064
MAX_ARRAY_BYTES : 16384
The value of MAX_ARRAY_BYTES is 16384, the default, as I expect.
However, my application is using CAJ to read arrays that are over 1.2MB
with no errors!  Is the max_array_bytes property actually not used in
CAJ?  It looks like it must be being ignored?
Well, CAJ does not ignore this property. It preallocates its buffers using MAX_ARRAY_BYTES value. However, if server sends a bigger array it replaces buffer with newly allocated (bigger one).
(This is not optimal regarding resource allocation, but it's very convenient on client side. I can put a "hard" limit there, if you wish...)
Matej
RE: CAJ questions Mark Rivers
Re: CAJ questions Matej Sekoranja
Prev: FW: EDM: Text Monitor Widget Szalata, Zenon M.
Next: RE: CAJ questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CAJ questions Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
