1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: UV cameras
To: "Dirk Zimoch" <[email protected]>, "tech-talk" <[email protected]>
Date: Wed, 5 Aug 2009 10:27:39 -0500
Dirk,
I don't have direct experience, but many CCD cameras can be ordered UV
sensitive, which involves removing the glass cover over the CCD chip.
It would be interesting to see if you can order the Prosilica GigE
cameras this way - I do have an EPICS driver for those.  There are also
EPICS drivers for Firewire cameras, which may also be available in UV
sensitive models.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Wednesday, August 05, 2009 10:02 AM
To: tech-talk
Subject: UV cameras
Hi all,
Does anyone have experience with UV cameras?
What model are you using?
What are the specs?
Do you have an EPICS driver?
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
UV cameras Dirk Zimoch
Prev: UV cameras Dirk Zimoch
Next: RE: CA reconnection problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Building ASYN on Windows John Dobbins
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
