1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA reconnection problem
To: "'Dirk Zimoch'" <[email protected]>, "'tech-talk'" <[email protected]>
Date: Wed, 5 Aug 2009 10:14:39 -0600
Dirk,
Some additional thoughts on your issue.
1) Depending on how your timing system is plumbed (with or without general
time), time-of-day (epicsTime::getCurent) might not advance if the timing
pulses are turned off for a shutdown, and if the time-of-day doesn?t advance
CAC will not expire its timers - this is required for it to send its search
requests.
2) See also mantis 299 and 330 which might or might not be related
PS: In the previous message I meant to say "that part isn?t different
between R3.13 and R3.14"
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Jeff Hill
> Sent: Wednesday, August 05, 2009 9:49 AM
> To: 'Dirk Zimoch'; 'tech-talk'
> Dirk,
> The R3.14 design is more conservative from a perspective of avoiding
> positive congestion feedback. Here are the primary differences.
> O When a circuit times out the CAC library disconnects the application,
> but
> not the circuit. We rely on TCP to decide when to give up on a circuit,
> and
> disconnect it.
> O When the CAC library sees a beacon anomaly the search rate receives a
> boost, but this boost is only to once every 5 seconds. In contrast, newly
> created channels are initially searched for at a rate which is closer to
> the
> average measured round trip time. The CAC library sends multiple search
> requests per UDP frame, and depending on past success rates also multiple
> UDP frames per periodic search attempt (that part isn?t different between
> R3.14 and R3.15). Nevertheless, if there many channels it can take a
> little
> while to connect all of them if the IOC (or GW in this situation has been
> off for a long time).
> O In R3.14 the CAC library never stops searching for disconnected
> channels,
> but the maximum search rate is adjustable with an environment variable.
> > I cannot see any search requests from that IOC.
> That doesn?t sound right, but bear in mind that if the IOC is sending
> unicasts, and not broadcasts, to the gateway on a switched network then
> the
> network sniffer may or may not see them if it isn?t listening at the
> source
> or the destination cables. Directed broadcasts may also not be seen by the
> network sniffer if it isn?t sniffing directly on the directed broadcast's
> destination subnet.
> The output from dbcar when its interest level argument is set very high
> (say
> to 100) will show many things about the internals of the CAC library.
> Also,
> there is a timer thread created by the CAC library that is scheduling the
> search requests, and you might send a stack trace (if it isn?t simply
> waiting on its time delay event flag).
> Another possibility is that something is amiss in the GW. Does restarting
> the GW improve the situation?
> Jeff
> > From: [email protected] [mailto:tech-talk-
> [email protected]]
> > On Behalf Of Dirk Zimoch
> > Sent: Wednesday, August 05, 2009 8:09 AM
> > To: tech-talk
> > Subject: CA reconnection problem
> > Hi all (Jeff in particular)
> > I have seen a problem with some of our IOCs today. Several beamline IOCs
> > running
> > 3.14.8 have disconnected CA input links to a central IOC (3.13.10) even
> > though
> > the channels are there. The beamline IOCs run behind ca gateways. It may
> > be that
> > the gateways or the central IOC had been offline for more than some
> hours
> > recently in the last shutdown.
> > Even though the channels are back and I can read them from the beamline
> > network
> > with caget the IOCs don't reconnect.
> > I have started a softioc in the beamline network to generate a beacon
> > anomaly
> > but even then the links do not reconnect. I cannot see any search
> requests
> > from
> > that IOC.
> > Only 3.14.8 systems show this problem. 3.13. systems don't. Is there a
> bug
> > in
> > the 3.14.8 implementation of CAC I should know of?
> > Dirk
> > Dr. Dirk Zimoch
> > Paul Scherrer Institut, WBGB/006
> > 5232 Villigen PSI, Switzerland
> > Phone +41 56 310 5182
CA reconnection problem Dirk Zimoch
RE: CA reconnection problem Jeff Hill
Prev: RE: CA reconnection problem Jeff Hill
Next: Building ASYN on Windows John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA reconnection problem Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
