1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TDS3000 Support for edm
To: [email protected]
Date: Fri, 14 Aug 2009 12:23:09 -0700
Hello,
I have been trying to get EDM to work with tds3000 device support.
I have installed the tds3000, 2-4, module and am running an IOC from the example IOC that it comes with. I used adl2edl to converted the MEDM screens and touched them up using EDM. I have control over the scope through the screens so I know it is communicating correctly. I have the following problem:
From the terminal where EDM is running I get:
CA add event error('RF1:1:chan4ScaledWaveWF'): The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
It happens whenever the graphs are trying to be drawn, IE. switching between multiple and single graphs cause each of the scope channels to produce these areas.
In my st.cmd file I have the line:
epicsEnvSet(EPICS_CA_MAX_ARRAY_BYTES, 100000)
I do not get any errors on the IOC terminal.
This makes me think that the problem is somewhere on EDM side. Reading through the old techtalk issues I read somewhere that EDM acts as a client to IOCs and both have different EPICS_CA_MAX_ARRAY_BYTES. How do I set EPICS_CA_MAX_ARRAY_BYTES on the EDM side? If that isn't the problem has anyone else hooked a scope to EDM displays successfully?
Mathew Hicks
RE: TDS3000 Support for edm Mark Rivers
Prev: Re: uptodate version of modtcp? Burkhard Kolb
Next: RE: TDS3000 Support for edm Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASYN R4-12 Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
