1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Agilent LXI via Ethernet + Asyn + StreamDevice?
To: Rod Nussbaumer <[email protected]>
Cc: [email protected]
Date: Fri, 21 Aug 2009 14:56:13 -0500
Asyn provides drivers for both the VXI-11 protocol and for simple TCP byte-pipes. So, regardless of which protocol the 33201A uses, you need only write streamDevice support.
On Aug 20, 2009, at 6:12 PM, Rod Nussbaumer wrote:
Epicureans:
A request to control an Agilent model 33210A Function Generator has come to our attention. The instrument is or can be equipped with an ethernet interface using the LXI standard interface. Has anyone used such an interface, especially with Asyn/ StreamDevice? Is it as simple as making a TCP connection and sending GPIB-like commands and reading a stream of data from the device? I have looked at the LXI standard online, but it seems to be written in a different revision of English than the one I am compatible with. A document on the Agilent web site suggests that it uses port 5025 in a telnet-like way to send and receive SCPI strings. If it is that simple, life will be good, here.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Agilent LXI via Ethernet + Asyn + StreamDevice? Rod Nussbaumer
Prev: Re: Intelligent Picomotor Control Modules from New Focus David Kline
Next: Re: 2 cents of pedantry Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Agilent LXI via Ethernet + Asyn + StreamDevice? Rod Nussbaumer
Next: Notice of APS Network Outages Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
