1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access security problem
To: <[email protected]>
Date: Thu, 10 Sep 2009 13:41:39 +0200
Sorry, I still think I am right !
I run my tests on a soft Linux IOC. The asDumpRules cmd seems to be asprules in my case. Here are my results with A=1 and A=2 following Andrew’s suggestion (A& … instead of A >> …).
With A=1 the 1rst RULE for WRITE is TRUE which is OK
With A=2 I A&2 = 2 which is NOT the TRUE value (TRUE corresponds to 1 and not to !=0):
Simulateur >
Simulateur >dbpf ASGVAL,1
DBR_LONG:           1         0x1
Simulateur >asprules
ASG(DEFAULT) {
        INPA(ASGVAL) value=1.000000
        RULE(1,READ,NOTRAPWRITE)
        RULE(1,WRITE,NOTRAPWRITE) {
                UAG(tous)
                HAG(hag)
                CALC("A&1") result=TRUE
                UAG(develop)
                HAG(hag)
                CALC("A&2") result=FALSE
                UAG(physique)
                HAG(hag)
                CALC("A&4") result=FALSE
                UAG(gournay)
                HAG(hag)
                CALC("A&8") result=FALSE
                UAG(epics)
                HAG(hag)
                CALC("A&16") result=FALSE
Simulateur >dbpf ASGVAL,2
DBR_LONG:           2         0x2
ASG(DEFAULT) {
        INPA(ASGVAL) value=2.000000
                UAG(tous)
                HAG(hag)
                CALC("A&1") result=FALSE
                UAG(develop)
                HAG(hag)
                UAG(physique)
                HAG(hag)
                UAG(gournay)
                HAG(hag)
                UAG(epics)
                HAG(hag)
Simulateur >
If now I change the 2nd rule from A&2 to A>>1, I have now TRUE:
DBR_LONG:           2         0x2
ASG(DEFAULT) {
                UAG(tous)
                HAG(hag)
                UAG(develop)
                HAG(hag)
                CALC("A>>1") result=TRUE
                UAG(physique)
                HAG(hag)
                UAG(gournay)
                HAG(hag)
                UAG(epics)
                HAG(hag)
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Martin L. Smith [mailto:[email protected]]
Envoyé : jeudi 10 septembre 2009 12:50
À : GOURNAY Jean-Francois
Cc : [email protected]
Objet : Re: Access security problem
Actually Andrew is correct. Take the "A&2" as an example, when bit 1 is TRUE
then the result of the CALC is TRUE, when bit 1 is FALSE then the result of
the CALC will be FALSE. TRUE being = 1 and FALSE being = 0.
This may be why you are seeing this problem. If you log into the IOC console
and issue this command you will see the value that CA access security thinks
your CALC _expression_ evaluates to as shown below.
asDumpRules
ASG(ID01ds_ACTION) {
         INPA(ID01ds:AccessSecurity) value=3.000000
         RULE(0,WRITE,TRAPWRITE) {
                 UAG(operator)
                 HAG(local)
                 CALC("A<3") result=FALSE
                 UAG(flcord)
                 HAG(flctrl,local)
                 CALC("A<2") result=FALSE
         RULE(1,WRITE,TRAPWRITE) {
                 UAG(sec01)
                 HAG(sec01)
                 CALC("A<1") result=FALSE
                 UAG(appdev)
Marty
GOURNAY Jean-Francois wrote:
> Dear Andrew,
> I think you are wrong. Remember that the CALC _expression_ must return TRUE or FALSE which will not be the case with A&2, A&4 ...
> I guess my scheme is correct. Everything works except this problem with this spiral2mgr user that I don't understand (see the table below from my previous mail). We will try to overcome it in a way or another ... unless somebody has another idea about it !!!
> J.F. Gournay
> CEA Saclay
> IRFU/SIS
> De : Andrew Johnson [mailto:[email protected]]
> Envoyé : mercredi 9 septembre 2009 16:56
> À : [email protected]
> Cc : GOURNAY Jean-Francois
> On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
>> I did more systematic tests and I have this strange situation:
>> ASGVAL  UAG      spiral2  spiral2mgr      gournay
>> 1       tous      W        W               W        OK
>> 2       develop   -        - (should be W) -        WRONG
>> 4       physique  W        -               -        OK
>> 8       gournay   -        W (should be -) W        WRONG
>> W : database WRITE access
>> - :  no write access
>> I modified the CALC expressions accordingly to Martin suggestion :
>> CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
>> CALC (A>0&&A<2) as my A value comes from a longout record.
> You're right there, but for historical reasons the relative precedence of
> the ">>" and "=" operators are different in C and CALC, so you do need to
> change your expressions:
>>             CALC("A&1=1")
> As Marty suggested "A&1" is sufficient here
>>             CALC("A>>1=1")
> CALC actually evaluates this as "A>>(1=1)" which is not what you mean.  You
> could use "(A>>1)=1" but I would suggest "A&2" here instead.
>>             CALC("A>>2=1")
> "A&4"
>>             CALC("A>>3=1")
> "A&8"
> Using fewer operators will also parse and execute faster.
>> This message sent yesterday didn't show up.
> That's because you actually sent it to tech-talk-bounces@aps., not to
> tech-talk@aps., and I didn't get a chance to forward it manually before you
> re-sent it.
> HTH,
> - Andrew
J.F. Gournay
CEA Saclay
IRFU/SIS
Re: Access security problem Martin L. Smith
Prev: Re: Killing a soft IOC which doesn't have an interactive shell David Kline
Next: "buffer over-write" problem with StringIn record Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
Next: Re: Access security problem Martin L. Smith
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
