1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Killing a soft IOC which doesn't have an interactive shell
To: "Rees, Nick (DLSLtd,RAL,DIA)" <[email protected]>, <[email protected]>
Date: Thu, 10 Sep 2009 07:00:43 -0500
Nick,
What version of EPICS base are you using?  I think some changes have been made in recent releases to improve the shutdown process.
From: [email protected] on behalf of Rees, Nick (DLSLtd,RAL,DIA)
Sent: Thu 9/10/2009 6:15 AM
To: [email protected]
Subject: Killing a soft IOC which doesn't have an interactive shell
We have a need to run IOC's on Linux without a stdin and are looking for
the best way to set this up. The IOC's are to be used in a test harness
so need to be run up and down automatically and repeatedly.
The obvious thing to do was to duplicate what is done with the "softIoc
-s" command, which is to execute the startup script and then call
epicsThreadExitMain. The problem is that once epicsThreadExitMain is
called the process shows up as <defunct> and doesn't respond to normal
signals and only dies with a kill -9.
The solutions we can think of are:
1. Wrap the IOC in screen or procServ and so it has a stdin
2. Don't call epicsThreadExitMain, but install a signal handler that
gives a semaphore and then takes the semaphore.
3. Use kill -9 to kill the IOC.
Is there a recommended way to do this? In many ways, option 2 seems
best, but there should be an Epics call that does that for us. I don't
know of one, but would be happy to contribute one if it was supported.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
RE: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
Prev: "buffer over-write" problem with StringIn record Maurizio Montis
Next: Re: Access security problem Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Killing a soft IOC which doesn't have an interactive shell David Kline
Next: RE: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
