1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: list all process variables, linux alarm handler
To: Matthieu Bec <[email protected]>
Cc: [email protected]
Date: Mon, 14 Sep 2009 23:20:25 -0400
The last cut and paste didn't make it:
Kay discusses the relationship between PVs, records and names at
http://www.aps.anl.gov/epics/tech-talk/2007/msg00853.php
Don
On 9/14/09 11:18 PM, "Don Dohan" <[email protected]> wrote:
> If you mean the pv crawler used for the IRMIS RDB, the crawler extracts and
> stores both the record name and user defined field type instance values.  The
> crawler maintains a link to the dbd file used in defining each record, making
> it possible to reconstruct the full record using both user defined field
> values and default field values.
> PVs, however are still something a little different - see Kay Kasemir's
> explanation
> On 9/14/09 9:09 PM, "Matthieu Bec" <[email protected]> wrote:
>> Hi all,
>> I'm having a terminology issue someone might help with, because the
>> comments posted on this thread appear to mix 'record' and 'PV'
>> terminology interchangeably. Most of the time it's clear, and although
>> there is a reasonable '1 to n' relation between the two, I can think of
>> example that relation can break. To give an example, say:
>>     ioc1 uses old xxx record type, that does not have .YYY field
>>     ioc2 uses new xxx record type, that has a new .YYY field
>> xxx 'record' (dbl/dbgrep etc) report the same thing.
>> but ioc2 use a newer version that might add/remove some fields (that I
>> think is what we really call PV = I think of it as the entity you get
>> over channel access)
>> So what does pvCrawl really look at: PVs or records? does it figure in
>> my example field .YYY exists in ioc2 but not ioc1?
>> Thanks
>> Matthieu
Re: list all process variables, linux alarm handler Matthieu Bec
Re: list all process variables, linux alarm handler Don Dohan
Prev: Re: list all process variables, linux alarm handler Don Dohan
Next: Re: list all process variables, linux alarm handler Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
