1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: What is all I need to know to write a CA protocal?
To: <[email protected]>
Date: Tue, 22 Sep 2009 08:23:30 +0200
Hello,
When I was writing a CA library in C# and I was strongly relying on the
cosylab epics protocol specification at:
http://epics.cosylab.com/cosyjava/JCA-Common/Documentation/CAproto.html
Also you may be able to read something out of the source code of the
library, which you find at:
http://gfa-it.web.psi.ch/epicsSharp/
At the moment I am writing an developer documentation for the library,
which does also contain some basic stuff about the protocol, and if you
are interested I'll send it to you, as soon as it is finished.
But I do also want to express my doubts that it is possible to do a CA
library with ActionScript. I am not really deep in ActionScript, but as
far as I do know, it's missing to much of the network support to be able
to do such a implementation.
Kind regards,
Christoph Seiler
-----Original Message-----
[mailto:[email protected]] On Behalf Of Zhichu Chen
Sent: Dienstag, 22. September 2009 07:40
To: [email protected]
Subject: What is all I need to know to write a CA protocal?
I'm planning to write an ActionScript library for CA, but I know little
about the network. Could any of you give me some advice about which
files in EPICS I should read?
It's all started because I'm not totally satisfied with EDM. It's ugly
(sorry to say that) and not platform-independent. I've tried some flash
recently and felt amazing, so I want to use ActionScript and Flex SDK to
make a beautiful and cross-platform interface.
By the way, compiling EDM is not an interesting trip. The open()
function should have three parameters but the one in utility.cc has only
two so I have to add the "mode" parameter: 0644, I'm not sure if it's
right, maybe 755 is better?
Anyway, on a 64bit Ubuntu with gcc version 4.3.3, I can't link
correctly, linking to libXm, libXp, blahblah.... reports "bad symbols"
errors, but I guess it's the compiler's problem.
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: What is all I need to know to write a CA protocal? Zhichu Chen
Prev: What is all I need to know to write a CA protocal? Zhichu Chen
Next: Re: What is all I need to know to write a CA protocal? Zhichu Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
