I think that is the 32-bit version, and you need the 64-bit version, which will be in usr/lib64
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/23/2009 9:02 PM
To: Zhichu Chen
Cc: [email protected]
Subject: Re: alarm handler on base 3-14-11
I think it is installed, there is a libncurses.so.5 file in /usr/lib.
Zhichu Chen wrote:
> Install ncurses library by yourself.
> On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
> <[email protected]> wrote:
>> Thank you, that seems to have worked. However, now it errors on 'cannot find
>> -lncurses' for g++ -o alh.
>> Mark Rivers wrote:
>>> This is a common change required in 3.14.11.
>>> You need to "#include menuYesNo.h" and YES needs to be changed to
>>> menuYesNoYES.
>>> Mark
>>> ________________________________
>>> Sent: Wed 9/23/2009 8:00 PM
>>> To: [email protected]
>>> Subject: alarm handler on base 3-14-11
>>> Hi,
>>> I was wondering, I get a compile error on force.c when running make on
>>> the alarm handler with epics-3-14-11, on 64 bit linux:
>>> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
>>> -D_REENTRANT -O3 -Wall -m64 -g -I. -I../O.Common -I.
>>> -I../os/default -I.. -I../../../include/os/Linux -I../../../include
>>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>>> -I/users/thomas/epics/base/base-3-14-11/include -I../os/Linux
>>> -I../os/default -I/usr/include -I/usr/include/X11 ../force.c
>>> ../force.c: In function 'forcePVUpdateFields':
>>> ../force.c:1028: error: 'YES' undeclared (first use in this function)
>>> ../force.c:1028: error: (Each undeclared identifier is reported only once
>>> ../force.c:1028: error: for each function it appears in.)
>>> make[2]: *** [force.o] Error 1
>>> make[2]: Leaving directory
>>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>>> make[1]: *** [install.linux-x86_64] Error 2
>>> make[1]: Leaving directory `/users/thomas/epics/extensions/src/alh1_2_24'
>>> make: *** [alh1_2_24.install] Error 2
>>> Thank you,
>>> Patrick
- Re: alarm handler on base 3-14-11 Patrick Thomas
- alarm handler on base 3-14-11 Patrick Thomas
- RE: alarm handler on base 3-14-11 Mark Rivers
- Re: alarm handler on base 3-14-11 Zhichu Chen
<2009>
2025
2026
<2009>
2025
2026
