1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: propagating value upward at init
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Fri, 02 Oct 2009 09:01:43 +0200
Hi, Emmanuel,
Emmanuel Mayssat wrote:
Hello,
I hope you are all doing well.
I may have asked this question a months ago, but ...
I have the following DB processing scheme
AO (high level PV name) --> AO ( hardware PV name) ---> hardware ---> AI (hardware PV name) --> AI (high level PV name)
When I set the first AO, the value is propagated to the other one (on OUT field), then to the hardware and finally read back on both of the AI.
The issue is that when I reboot the IOC, the first AO is reset to 0.
Ultimately I would like it to be set at current value (read hardware first and then set value accordingly).
In the device support, set the return value of init_record() to 0, then in the ao record support, its init_record will computes the VAL form RVAL using the algorithm:
VAL = ((RVAL+ROFF) * ASLO + AOFF) * ESLO + EOFF
please refer to "EPICS 3-14 Record Reference Manual"
Good luck,
Gongfa
With AI with a PINI=YES, I can see what the hardware value in both AI.
How can I load the CURRENT hardware value in the 1st AO at init?
( I use base < 3.14.11, so not so easy to use multilayer aliasing!!)
Additionally could someone give an example where the DOL + OMSL field are commonly used?
I wonder what the practical purposes of those fields are.
Emmanuel
Gongfa Liu                         MKS-2, DESY
phone:  +49-40-8998-1642           Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]         Germany
propagating value upward at init Emmanuel Mayssat
Prev: propagating value upward at init Emmanuel Mayssat
Next: Re: propagating value upward at init Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
