1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: state notation code flags
Cc: [email protected]
Date: Fri, 02 Oct 2009 17:29:42 -0700
This also prints out the flag:
program sncTest
float test_put;
assign test_put to "H3:TEST_PUT";
monitor test_put;
evflag test_putEvent;
sync test_put test_putEvent;
float test_get;
assign test_get to "H3:TEST_GET";
monitor test_get;
evflag test_getEvent;
sync test_get test_getEvent;
ss ss1 {
	state init {
		when () {
			efClear(test_getEvent);
			pvGet(test_get);
			if (efTest(test_getEvent)) {
				printf("flag set\n");
		} state wait
		when () {
			efClear(test_putEvent);
			test_put = 40;
			pvPut(test_put, SYNC);
		} state wait
	state wait {
		when () {
			if (efTest(test_putEvent)) {
		} state wait
		when () {
		} state wait
Mark Rivers wrote:
Patrick,
pvGet will not set the event flag.  Event flags are only set on monitor
callbacks, i.e. when the value changes in the IOC and it does callbacks
to channel access clients that have subscribed to that channel.
pvGet(pv) normally blocks for the operation to complete, so it gives the
same behavior as pvGet(pv, SYNC) (unless you compiled with the +a
option, which I would not recommend).
pvPut(pv) and pvPut(pv, SYNC) do behave differently, because the default
behavior is not to wait for the pvPut to complete, adding the SYNC
option forces it to wait for the put to complete.
-----Original Message-----
From: Patrick Thomas [mailto:[email protected]] Sent: Friday, October 02, 2009 1:25 PM
To: Mark Rivers
Hi Mark,
If I have the following:
float request_move_to_absolute_position;
assign request_move_to_absolute_position to "{IFO}:{DRIVER}_REQUEST_MOVE_TO_ABS_POS_{AXIS}";
monitor request_move_to_absolute_position;
evflag request_move_to_absolute_positionEvent;
sync request_move_to_absolute_position request_move_to_absolute_positionEvent;
pvGet(request_move_to_absolute_position);
efClear(request_move_to_absolute_positionEvent);
Will the pvGet set the request_move_to_absolute_positionEvent flag? If so, is it possible that even with the efClear, the flag will remain set at the end of the code, because the pvGet will not have completed before
the efClear is encountered? But if pvGet(request_move_to_absolute_position, SYNC) is used, will this guarantee that the efClear will clear the flag?
Thank you,
Patrick
Mark Rivers wrote:
Patrick,
Event flags can be explicitly set, which is typically used to allow
communication between state sets.  Or event flags can be synced to a
PV,
and will be set whenever a monitor is received for that PV, as in the
example I sent you.
You can use the efTest() function outside of a when statement, just
like
any other function.
From: Patrick Thomas [mailto:[email protected]] Sent: Thursday, October 01, 2009 5:20 PM
To: Mark Rivers
Hi Mark,
Are the flags on a monitored variable set whenever the monitored variable is used in the code, including a pvPut, pvGet, assignment, calculation, or print statement? Is there a way to test if the flag is
set besides an efTest in a when statement?
Thank you,
Patrick
Mark Rivers wrote:
Hio Patrick,
Here are some code snippets from one of my SNL programs.  It has a
variable nelements assigned to a PV, and a monitor on that PV.  It has
an event flag, nelementsMon that is synced to nelements.  Whenever
nelements changes the event flag will be set.  In the init state I
clear
the event flag, just to be sure it is clear when the SNL code starts
running (after all PVs connect).  I then use efTestAndClear in a when
statement to take actions when that event flag is set, and to clear
it.
This works fine for me.
int     nelements;   assign nelements    to "{P}{R}Nelements.VAL";
monitor nelements;
evflag nelementsMon;    sync nelements  nelementsMon;
    /* Initialize things when first starting */
    state init {
        when() {
            /* Clear all event flags */
            efClear(nelementsMon);
        } state monitor_inputs
    state monitor_inputs {
        when(efTestAndClear(nelementsMon) && (nelements>=1)) {
            /* If nelements changes, then change endPulses to this
value,
             * since this is what the user normally wants.  endPulses
can be
             * changed again after changing nelements if this is
desired. */
            if (moveMode == MOVE_MODE_RELATIVE)
                endPulses = nelements;
            else
                endPulses = nelements-1;
            pvPut(endPulses);
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/30/2009 10:35 PM
To: [email protected]
Subject: state notation code flags
I was wondering if there is a way to track at what point in the state
notation code evflags are getting set and cleared, or if someone
could
clarify under what conditions they get set. I'm having trouble with
them
getting set somewhere and not being cleared, but I'm not sure where.
Thank you,
Patrick
RE: state notation code flags Mark Rivers
state notation code flags Patrick Thomas
Re: state notation code flags Patrick Thomas
Prev: Re: state notation code flags Patrick Thomas
Next: Re: EPICS Python client application survey Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: state notation code flags Mark Rivers
Next: RE: state notation code flags Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
