1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: state notation code flags
To: [email protected]
Date: Mon, 5 Oct 2009 10:16:04 -0500
Gentlemen,
On Saturday 03 October 2009 08:05:37 Mark Rivers wrote:
> What is it you are trying to do?  You are doing both pvPuts and looking for
> external changes to the same PV?
> If so, then one solution is to ignore events which correspond to the value
> that your SNL program set with pvPut, and only act on events with values
> that must have been done by some external agent.  Here is an example from
> one of my programs:
> int abort;
> assign abort to "{P}{R}Abort.VAL";
> monitor abort;
> evflag abortMon;
> sync abort abortMon;
> ss xpsTrajectoryAbort {
>     state monitorAbort {
>         when ((efTestAndClear(abortMon)) && (abort==1) &&
>               (execState==EXECUTE_STATE_EXECUTING)) {
>             abort=0;
>             pvPut(abort);
>         } state monitorAbort
I believe the issue you are both discussing is a classic case of a race
condition which is caused by doing exactly what Mark discusses.  I suspect
it's possible that the monitor callback can occur and change the value of the
abort variable above in between the lines abort=0 and pvPut(abort), but even
if that's not possible it is still causing the problems that Patrick is
seeing.  It is unfortunate that the design of the SNL language makes this
possible, and it may require some major surgery to fix this in the
implementation.
However there is an easy solution, which I'm pretty sure will fix Patrick's
issue: Add a second variable pointing to the same PV which is not monitored
and is used only to do the pvPut operations.  Copying Mark's example, I've
added the abortOut variable and removed the test of the abort value from the
when() condition, although it's possible that you might still want that.
int abort;
int abortOut;
assign abortOut to "{P}{R}Abort.VAL";
monitor abort;
evflag abortMon;
        when (efTestAndClear(abortMon) &&
            abortOut=0;
            pvPut(abortOut);
If you adopt this model, you're never changing the value of the abort variable
yourself, and I think you'll find that the result will only set the event flag
once, when your put value makes its way back to you via the monitor.
I suspect it would be a good idea to try and get the the SNL compiler to issue
a warning whenever it sees someone calling pvPut() on a variable which has a
monitor on it, since this is IMHO an unsafe practice.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: state notation code flags Mark Rivers
Re: state notation code flags Benjamin Franksen
state notation code flags Patrick Thomas
Re: state notation code flags Patrick Thomas
Prev: Re: EPICS Python client application survey Michael Abbott
Next: RE: Channel access and ca_element_count Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: state notation code flags Mark Rivers
Next: RE: state notation code flags Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
