1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel access dynamic array subscription update element count
To: Jeff Hill <[email protected]>, [email protected]
Cc: [email protected]
Date: Mon, 5 Oct 2009 11:20:25 -0500
Jeff,
While you're responding on this subject could you definitively answer
Micheal's original questions, which were:
> Firstly, is it possible for the element count of a channel to change while
> the channel is connected?  I'm thinking in particular of the case when
> using camonitor (well, ok, I mean ca_create_subscription()) to monitor a
> waveform PV.  Each event_handler callback is informed of the dbr count --
> but as far as I can tell, it's always the maximum waveform size, even if
> NORD is smaller.
> Is the fact that the update size doesn't change, ca_element_count() always
> reports the NELM, and subscribing with zero count gets the full wavelength,
> is this restriction fundamental to channel access, a limitation of the
> channel access server, or just something that hasn't been implemented in
> the waveform record?  This question becomes more interesting as we use
> waveform records for large images!
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Channel access dynamic array subscription update element count Michael Abbott
RE: Channel access dynamic array subscription update element count Jeff Hill
javaIOC Marty Kraimer
Channel access and ca_element_count michael.abbott
RE: Channel access and ca_element_count Jeff Hill
Prev: Re: state notation code flags Andrew Johnson
Next: Re: Channel access dynamic array subscription update element count Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Channel access dynamic array subscription update element count Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
