Hi William,
I has a similar problem with the MVME4100, which is also based on a e500 core
like your MVME3100. Finally, I had to use vxWorks 6.7 which provides a newer
compiler. I guess that the compiler options were done for vxWorks 6 and vxWorks
5 does not know about CPU=PPC32.
Maybe you have to modify the compiler options in the EPICS make configurations
to work with vxWorks 5. I suggest to find out which options vxWorks uses when it
builds the kernel. You may also have a look at the processor specific supplement
documentation of vxWorks.
Hope that helps
Dirk
William F. Steele wrote:
I don't understand how to build EPICS for MVME3100. I have no problem
with mcp750, mvme2100, 68040, or 68060. I am trying to build EPICS
3.14.11 and am using vxWorks 5.5.1 with Tornado 2.2.1. If I put
vxWorks-mpc8540 in my list of CROSS_COMPILER_TARGET_ARCHS, I get
compile errors which I traced to ARCH_DEP_CPPFLAGS which is set to
-DCPU=PPC32 which the compiler does not recognize. If I change that to
ARCH_DEP_CPPFLAGS = -DCPU=PPC85XX, then I no longer get compile errors,
but EPICS will not load due to a lot of undefined symbols. I talked to
WRS about this problem and was advised that I was using the wrong
compiler. When I use Tornado to build vxWorks, Tornado uses
/home/als2/devel/vxWorks/tornado2.2.1-ppc/host/gnu/3.3/sun4-solaris2/bin/ccppc,
but when building EPICS, the EPICS build system uses
/home/als2/devel/vxWorks/tornado2.2.1-ppc/host/sun4-solaris2/bin/ccppc,
so, apparently, the EPICS build system does not automatically setup to
use the correct tools when specifying the target
vxWorks-mpc8540. What needs to be done to make this work right? Thanks.
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- EPICS build for MVME3100 William F. Steele
procServ softIOC server - V2.4.1 released Ralph Lange
<2009>
2025
2026
Re: EPICS build for MVME3100 Ron Sluiter
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
