1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compiling streamDevice with CALC set fails
To: "Dr. Peter Zumbruch" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 21 Oct 2009 12:10:54 -0500
Peter,
EPICS 3.14.10 doesn't build libiocsh, as previous versions id.
You need to remove iocsh from the line
LIB_LIBS += stream dbIoc registryIoc iocsh
in srcSynApps/Makefile.
You'll still get iocsh, because base now has it in libCom.
Tim
Dr. Peter Zumbruch wrote:
Hi everybody,
when compiling streamDevice 2.4 from psi web page with CALC set in the
RELEASE file
I get the following output
base: 3.14.10, Debian 4.0
make[2]: Entering directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps/O.linux-x86'
Installing created dbd file ../../../dbd/streamSynApps.dbd
/usr/bin/gcc-3.4 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC
-I. -I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include -I<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12/include
-I<EPICS_TOP>/base-3.14.10/include/os/Linux
-I<EPICS_TOP>/base-3.14.10/include -I<EPICS_TOP>/modules/soft/asyn/asyn-4.10/include -I<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7/include ../devscalcoutStream.c
/usr/bin/ar -rc   libstreamSynApps.a         devscalcoutStream.o
/usr/bin/ranlib libstreamSynApps.a
make[2]: *** No rule to make target
`../../../lib/linux-x86/libiocsh.a', needed by `libstreamSynApps.so'. Stop.
make[2]: Leaving directory
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps'
make: *** [srcSynApps.install] Error 2
without CALC set, everything compiles the right way.
and here the corresponding RELEASE
#RELEASE Location of external products
#If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=<EPICS_TOP>/base
ASYN=<EPICS_TOP>/modules/soft/asyn/asyn-4.10
CALC=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7
PCRE_INCLUDE=/usr/include/pcre
PCRE_LIB=/usr/lib
Any help would be appreciated,
Peter
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
Prev: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
Next: devLibOSD.c for Linux Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
