Hi Christophe,
On Tuesday 27 October 2009 10:38:06 haquin wrote:
> But can you still answer the following questions:
> - is it possible to initialize an array with a MACRO (be it numeric or
> string) ? - is it possible to initialize a string array from the startup
> script using dbpf command or else ?
No, it is not currently possible to initialize array fields before iocInit
(that includes using dbLoadRecords), since the memory to store the array data
is not allocated until the record initialization takes place. The best
suggestion the community has for doing this is to use an autosave/restore
program to set the array during the IOC start-up. That could also be used to
set string fields.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- can't initialize record field with string haquin
- Re: can't initialize record field with string Andrew Johnson
- Re: can't initialize record field with string haquin
Re: can't initialize record field with string Bruce Hill
<2009>
2025
2026
<2009>
2025
2026
