1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS BACnet Support
To: <[email protected]>
Date: Wed, 28 Oct 2009 15:56:18 -0000
Hello,
I am currently working on this, initially just to read some BACnet values into an EPICS Linux IOC, though progress is slow as I'm just fitting it in around other jobs. When I inquired it seemed as if nobody had done much work on BACnet for a couple of years or more.
My development is following as closely as possible the work done at TRIUMF in Canada, by Rod Nussbaumer. (Rod, I hope you don't mind me mentioning you.)
Marty Kraimer also developed BACnet support for the javaIOC, for DESY. I believe this needs some updating to work with the latest javaIOC, but that should not be too onerous. (Marty, sorry for another name drop.)
Regarding the TRIUMF work, Rod has been very helpful sending me large amounts of code and answering lots of questions but I have not yet got everything working. The route is a little tortuous due to all the different tools required and my lack of knowledge, but having gone through it recently it should be less painful again. The BACnet part of the code is a modified version (0.3.10) of bacnet4linux.(http://sourceforge.net/projects/bacnet4linux/) See also, http://bacnet4linux.sourceforge.net/.
However this is now obsolete regarding further development (even the later 0.3.12 version) and replaced by the BACnet Stack project, see http://bacnet.sourceforge.net/ and http://sourceforge.net/projects/bacnet/
I chose to stick with Rod's method however as it provides far more than just a BACnet stack. The bacnet4linux package includes a web server which was very useful initially for checking communications on the BACnet interface. Then the browsing and selection of PVs is web based, using a Perl script to talk to a PostgresQL database. This script also generates EPICS records and EDM panels, making it much easier to change the set of PVs we want to monitor.
Let me know if you want more detail of the whole system. It could be much more complex than you need.
If you wished to develop EPICS BACnet support yourself, I think there are several other BACnet stacks available, but mostly commercial and mostly geared up to adding BACnet support to the remote servers, interfacing to hardware and not specifically for the client (management) side.
It depends exactly what you want to do with the BACnet support as to whether these are any use.
Keith Baker
Controls Group
Diamond Light Source Ltd
+44(0)1235 778054
From: [email protected] [mailto:[email protected]] On Behalf Of Debby Quock
Sent: 28 October 2009 13:03
To: [email protected]
Subject: EPICS BACnet Support
EPICS Colleagues,
Is any one currently using and/or developing EPICS support for BACnet data communication protocol? More specifically, EPICS-to-BACnet driver that is used with commercial heating and ventilation control systems.
Debby Quock
Controls Group
Advanced Photon Source
Argonne National Laboratory
Re: EPICS BACnet Support Marty Kraimer
EPICS BACnet Support Debby Quock
Prev: EPICS BACnet Support Debby Quock
Next: RE: macLib/msi changes with 3.14.10 nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS BACnet Support Marty Kraimer
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
