1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA link behavior
To: [email protected]
Date: Fri, 13 Nov 2009 14:24:28 -0600
Hi Geoff,
On Friday 13 November 2009 13:38:36 Geoff Savage wrote:
> I have a passive stringout record in IOC A whose OUTLINK references an
> mbbo record in IOC B.  When I reboot IOC B the value in the stringout
> record is written to the mbbo record even though the stringout record
> has not been processed.
> A bit more background.  The stringout record will be processed by a
> calc record when a temperature becomes too high.  The mbbo record
> controls the power to a front end board.  So the value being written
> is to power off the front end board whenever the IOC B is rebooted.
This doesn't sound like it should be happening, unless there's something else
going on.  Have you tried setting TPRO on the mbbo record?  The output from
    dblsr "<mbboRecordName>", 2
might provide some more clues as well.
Can you post the two complete record definitions extracted from their .db
files, and the output from dbpr on both records with an interest level 3 or
higher.  Also the Base version number that you're running (and whether it
contains any significant modifications to the official release), and the
target architectures of the two IOCs for completeness sake.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: CA link behavior Ralph Lange
Fwd: CA link behavior Geoff Savage
Prev: CA link behavior Geoff Savage
Next: Re: CA link behavior Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
