1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub and C++
To: [email protected]
Cc: Simon Hoyle <[email protected]>
Date: Mon, 16 Nov 2009 09:48:12 -0600
Hi Simon,
On Sunday 15 November 2009 19:18:08 Simon Hoyle wrote:
> I'm attempting to use some C++ code in the subroutine of an
> aSub record in Epics base 3.14.10.
> There is a problem compiling the subroutine due to the occurrence
> of the C++ reserved word 'not' in the aSubRecord header file.
> Is there a way around this ?
Since you're not trying to compile the record code itself using C++ the
simplest way is probably to do this in your subroutine source file:
    #define not no_t
    #include "aSubRecord.h"
and make sure you use prec->no_t if you ever need to access that field in your
code.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
aSub and C++ Simon Hoyle
Prev: Re: aSub and C++ Ian Gillingham
Next: sscan, asyn and mutexes [SEC=UNCLASSIFIED] LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
