Damien,
I think the problem might that version 2-6-5 of the sscan module is not
ready for a 64-bit architecture. sscanRecord.c contains some structures
that are supposed to match exactly the record structure defined in the
sscanRecord.h include file, which is generated by the EPICS build from
sscanRecord.dbd. But the definitions in sscanRecord.c do not match
exactly anymore, and the code must be modified. Mark Rivers did this,
but I haven't published a version of the sscan module with Mark's fixes.
I'm sending you a copy of the most recent sscanRecord.c, but I'll not
blast it to all tech-talk recipients. Please try this and see if the
problem goes away or at least changes.
Tim
LYNCH, Damien wrote:
Has anyone run into the following mutex locking failure before? I have
only seen the problem when drvSerialPortConfigure is called and a sscan
record is loaded. In the example below there is only the sscan record
specified in sscantest.db. Occasionally the IOC will start fine.
We have been running an IOC using base 3.14.9, asyn 4.9 and sscan 2-5-6
and never seen this problem.
dly@antares14:~/sscantest/iocBoot/iocsscantest>
../../bin/linux-x86_64/sscantest st.cmd
#!../../bin/linux-x86_64/sscantest
## You may have to change sscantest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocsscantest")
epicsEnvSet("TOP","/home/dly/sscantest")
epicsEnvSet("ASYN","/usr/local/src/EPICS/asyn/4-12")
epicsEnvSet("SSCAN","/usr/local/src/EPICS/sscan/2-6-5")
epicsEnvSet("EPICS_BASE","/usr/local/src/EPICS/base-3.14.11")
cd /home/dly/sscantest
dbLoadDatabase "dbd/sscantest.dbd"
sscantest_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("src", "/dev/ttyr07")
## Load record instances
dbLoadRecords("db/sscantest.db","user=dlyHost")
cd /home/dly/sscantest/iocBoot/iocsscantest
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Nov 16 2009
A call to 'assert(status == epicsMutexLockOK)'
by thread '_main_' failed in ../dbPvdLib.c line 90.
EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
Local time is 2009-11-16 14:24:25.500100161 EST
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
Damien Lynch
Accelerator IT Systems Engineer
Institute of Environmental Research
Australian Nuclear Science and Technology Organisation
PMB 1, Menai NSW 2234
Important: This transmission is intended only for the use of the
addressee. It is confidential and may contain privileged information or
copyright material. If you are not the intended recipient, any use or
further disclosure of this communication is strictly forbidden. If you
have received this transmission in error, please notify me immediately
by telephone and delete all copies of this transmission as well as any
attachments.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
- RE: sscan, asyn and mutexes [SEC=UNCLASSIFIED] LYNCH, Damien
- sscan, asyn and mutexes [SEC=UNCLASSIFIED] LYNCH, Damien
<2009>
2025
2026
<2009>
2025
2026
