1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: why doesnt the include file install set the file permisions to unwritable?
To: "'Maren Purves'" <[email protected]>
Cc: [email protected]
Date: Wed, 18 Nov 2009 17:43:50 -0700
Hi Maren,
> so that the next person can overwrite it?
> We generally have more than one person working on things, at
> least over the years.
The issue is that the source file, maintained in the source directories, can
be (should be) modified (overwritten) but the installed file, installed into
base/include generally shouldn?t be changed. If you do make changes in the
include directory it generally causes massive headaches with the
dependencies in the build system.
So from my perspective the installed file should be immutable, but also
hopefully over-writable only after some judicious use of persuasion in the
installer program.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Maren Purves [mailto:[email protected]]
> Sent: Wednesday, November 18, 2009 5:17 PM
> To: Jeff Hill
> Subject: Re: why doesnt the include file install set the file permisions
> to unwritable?
> Jeff,
> Maren
> Jeff Hill wrote:
> > So, given this perspective and some others, it appears to be sensible
> for
> > all include files to have their permissions set to un-writable when they
> are
> > installed, but maybe there is some practical issue that prevents this
> from
> > being standard behavior that I don?t see?
why doesnt the include file install set the file permisions to unwritable? Jeff Hill
Prev: why doesnt the include file install set the file permisions to unwritable? Jeff Hill
Next: Re: why doesnt the include file install set the file permisions to unwritable? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
