1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: error building mca6-11
To: "tech-talk" <[email protected]>
Date: Fri, 20 Nov 2009 13:28:02 +0800
hi,
when I tried to compile the mcaR6-11/10, I met following errors:
/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`   -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-12/include  -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include  -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -I/usr/local/epics/r3.14.10/base/include/os/Linux -I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
In file included from /usr/include/libnet.h:124,
                 from ../nmc_sys_defs.h:56,
                 from ../nmc_comm_subs_1.c:69:
/usr/include/./libnet/libnet-functions.h:1432: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
make[3]: *** [nmc_comm_subs_1.o] Error 1
make[3]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
make[1]: *** [CanberraSrc.install] Error 2
make[1]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
make: *** [mcaApp.install] Error 2
root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
Any suggestion?  thanks a lot.
ps, I use ubuntu, libnet1 with apt-get install ,not from source compilation.
Best regards
Geyang  2009-11-20
RE: error building mca6-11 Mark Rivers
RE: error building mca6-11 Davidsaver, Michael
Prev: Re: why doesnt the include file install set the file permisions to unwritable? Andrew Johnson
Next: RE: error building mca6-11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
