1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Modbus help
To: <[email protected]>, <[email protected]>
Date: Wed, 25 Nov 2009 12:34:51 -0600
Emma,
Once you get the communication with a single device working, you are
going to run into problems trying to communicate with multiple RS-485
devices through a single serial port.  The reason is that I am using the
asynInterposeInterface layer to add the RTU header with the slave
address.  But asyn only allows a single interposeInterface for each asyn
port, which restricts one to a single slave address.
Yves Lussignol from CEA has fixed this problem, by moving the slave
address management to layer 2 (asyn port driver) from layer 3 (interpose
interface).  He sent me a modified version of the driver with this fix
back in March 2009, but I have been remiss in not testing it and
releasing a new version of the driver.  It does change the syntax of the
drvModbusAsynConfigure command, so it will be a major release, i.e. 2-0.
I will try to get a new release out in the next couple of weeks.
!RE: Modbus help emma.shepherd
RE: Modbus help Mark Rivers
Prev: RE: Modbus help Mark Rivers
Next: DEC driver DMA Underflow Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: !RE: Modbus help emma.shepherd
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
