1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ softIOC server - V2.5.0 released
To: [email protected]
Date: Wed, 2 Dec 2009 17:18:09 -0600
On Wednesday 02 December 2009 16:51:28 Emmanuel Mayssat wrote:
> I use procServ, but is there a tool to check whether an ioc was started
> on a particular computer?
> If not, I would like to be able to start the ioc (procServ process)
> remotely.
Why not just use the cainfo program that comes with Base to connect to a known
PV living on that IOC (we have a heartbeat PV on all our IOCs which would be
ideal for that).  That will tell you whether the IOC is up or not and which
host it's running on.  If you want to wrap that query in something a little
more polished I'd suggest looking at the equivalent cainfo.pl Perl script in
base/src/cap5 which you can use as the basis for adding application-specific
functionality, including starting the IOC if that's what you want.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
procServ softIOC server - V2.5.0 released Ralph Lange
Re: procServ softIOC server - V2.5.0 released Emmanuel Mayssat
Prev: Re: procServ softIOC server - V2.5.0 released Emmanuel Mayssat
Next: RE: procServ softIOC server - V2.5.0 released Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
