1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Prosilica GE1350
To: "Steve Kinder" <[email protected]>, "epics" <[email protected]>
Date: Fri, 4 Dec 2009 09:45:22 -0600
Hi Steve,
areaDetector should work with all Prosilica GigE cameras.  I have used the GC1360, which is very similar to the GE1350.  Have you already purchased the camera?  If not, the GC series are newer, cheaper and faster.
Will you run it under Linux or Windows?  If Linux then there is a patch needed for EPICS base 3.14.10.  It works fine with 3.14.11.  If you use the pre-built version of areaDetector this is not an issue, since it was built with the necessary patch.
From: [email protected] [mailto:[email protected]] On Behalf Of Steve Kinder
Sent: Friday, December 04, 2009 8:54 AM
To: epics
Subject: Prosilica GE1350
I would like to interface to a Prosilica GE1350 CCD camera and I believe this should be ok from the areaDetector package. Please could anyone confirm successful use of this combination or my belief.
Thanks
Steve
Prosilica GE1350 Steve Kinder
Prev: Prosilica GE1350 Steve Kinder
Next: Re: Prosilica GE1350 John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
