David Dudley wrote:
I have a project where I need to cross build some of the EPICS
extensions for another architecture.
Specifically, I want to build the ChannelArchiver to run on a remote
Linux host.
I already have the IOS compiled for the host (linux-xscale_be), and it
works well, with all the libraries and programs functional on that
architecture, but to make the machine I’m setting up an independent
system, I need to run the ChannelArchiver as well on that device.
I defined ‘CROSS_COMPILER_TARGET_ARCHS’ in the extensions configure
directory to ‘linux-xscale_be’, and when I build, I create a xscale_be
bin directory, however the build system doesn’t pick up the target build
tools, so it’s building 2 copies of the host programs.
What do I adjust to make the extensions build system pick up the proper
toolset?
David Dudley
You will need to create
base/configure/os/CONFIG_SITE.linux-x86.linux-xscale_be
In it, you can assign to '$GNU_DIR' the path to your cross tools. When
you do this, leave off any trailing 'bin' directory name, as EPICS build
will append this by itself. See the corresponding files for other
architectures as a guide.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
- Re: Cross Building Extensions Michael Abbott
- Cross Building Extensions David Dudley
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
