1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: camonitor and caget - displaying unsigned longs in hexadecimal
To: <[email protected]>
Date: Fri, 4 Dec 2009 16:15:50 -0800
Hi Andrew,
Thanks for the detailed explanation.  Unfortunately, camonitor doesn't
support the -d option (and I'd really like to see hex from camonitor).
This should be something possible with some code modification, I think.
Thanks again,
Stephanie
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, December 04, 2009 3:55 PM
> To: [email protected]
> Cc: Allison, Stephanie
> Subject: Re: camonitor and caget - displaying unsigned longs in
hexadecimal
> Hi Stephanie,
> On Friday 04 December 2009 17:16:34 Allison, Stephanie wrote:
> > I notice that camonitor and caget do not honor the "-0x" option
(option
> > to printout as hex) for PVs that are unsigned long's.  Such PVs are
sent
> > over CA as double's and -0x is not available for doubles, per
design.
> > Are there other options that I could use instead?    Should I look
into
> > changing the tools to allow for -0x for unsigned long's?
> CA can't transport unsigned types as such, although the IOC database
supports
> them.  If you do a cainfo of one of your ULONG PVs you'll see that its
native
> type actually gets reported as a DBF_DOUBLE, which is the smallest
type that
> CA can guarantee will pass any ULONG value correctly.  Unfortunately
CA gives
> no indication of what the real database type is, so I don't think the
tool
> could properly detect that the field is really a ULONG.
> However if you ask caget or camonitor to use DBR_LONG when fetching
the value
> (add the switch -d LONG) then it does honor the -0x switch, but the
display
> format is different.  Also if your client is a 64 bit machine you
might get
> the sign bit extended for display.  This is the output I get on
linux-x86_64
> when the top bit is set (note that the DBF_LONG and DBR_LONG types are
only 32
> bits wide even on 64-bit architectures):
> tux% caget -d LONG -0x anjHost:compressExample.N
>     Native data type: DBF_DOUBLE
>     Request type:     DBR_LONG
>     Element count:    1
>     Value:            0xFFFFFFFF80000000
> HTH, HANW,
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald
Welte
Re: camonitor and caget - displaying unsigned longs in hexadecimal Eric Norum
camonitor and caget - displaying unsigned longs in hexadecimal Allison, Stephanie
Re: camonitor and caget - displaying unsigned longs in hexadecimal Andrew Johnson
Prev: Re: camonitor and caget - displaying unsigned longs in hexadecimal Andrew Johnson
Next: Re: camonitor and caget - displaying unsigned longs in hexadecimal Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
