1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn R4.10, R4.11, R4.12
To: "Szalata, Zenon M." <[email protected]>, "Eric Norum" <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Sun, 6 Dec 2009 11:54:20 -0600
Hi Zen,
I think the best solution to this is for the default implementation of asynOctet->getInputEos and getOutputEos to return asynSuccess and *eoslen=0.
I've attached a patch for asynOctetBase.c against the R4-12 release.  Can you give it a try and see if it fixes the problem?
Sent: Sun 12/6/2009 10:51 AM
To: Mark Rivers; Eric Norum
Hi Mark,
Here is the result of dbpr "CAM:ASYN:IO",5:
epics> dbpr "CAM:ASYN:IO",5
ACKS: NO_ALARM      ACKT: YES           ACMD: None          ADDR: 12
AINP:               AOUT:               AQR: 0              ASG:
ASP: 0x00000000     AUCT: autoConnect   BAUD: Unknown       BINP: 0
BKPT: 0x00          BOUT: 0             CNCT: Connect       DBIT:
Unknown
DESC: asyn IO       DISA: 0             DISP: 0             DISS:
NO_ALARM
DISV: 1             DPVT: 0xf0f85c09    DRVINFO:            DSET:
0x488a5b00
DTYP: asynRecordDevice                  ENBL: Enable        EOMR: None
ERRS: 0xd8fb5c09    EVNT: 0             F64INP: 0           F64IV: 0
F64OUT: 0           FCTL: Unknown       FLNK:DB_LINK CAM:FO:IO:DATA
GPIBIV: 1           I32INP: 0           I32IV: 1            I32OUT: 0
IEOS:               IFACE: asynOctet    IFMT: Binary        IMAX: 80
IPTR: 0x28fb5c09    LCNT: 0             LSET: 0xd0d35d09    MCTL:
Unknown
MLIS: 0x000000000000000000000000        MLOK: 0xd8f85c09    NAME:
CAM:ASYN:IO
NAWT: 0             NORD: 0             NOWT: 6             NRRD: 0
NSEV: NO_ALARM      NSTA: NO_ALARM      OCTETIV: 1          OEOS:
OFMT: Binary        OMAX: 80            OPTIONIV: 1         OPTR:
0xd0fa5c09
PACT: 0             PCNCT: Connect      PHAS: 0             PINI: NO
PORT: L0            PPN: 0x00000000     PPNR: 0x00000000    PRIO: LOW
PROC: 0             PRTY: Unknown       PUTF: 0             RDES:
0x58855909
REASON: 0           RPRO: 0             RSET: 0x008a5b00    SBIT:
Unknown
SCAN: Passive       SDIS:CONSTANT       SEVR: NO_ALARM      SOCK:
SPR: 0              SPVT: 0x00000000    STAT: NO_ALARM      TB0: On
TB1: Off            TB2: Off            TB3: Off            TB4: Off
TFIL: Unknown       TIB0: Off           TIB1: Off           TIB2: Off
TIME: 2009-12-06 08:51:04.871003000     TINP:               TIOM: 0
TMOD: Write/Read    TMOT: 1             TMSK: 1             TPRO: 0
TSE: 0              TSEL:CONSTANT       TSIZ: 80            UCMD: None
UDF: 0              UI32INP: 0          UI32IV: 0           UI32MASK:
4294967295
UI32OUT: 0          VAL:
epics>
Zen
-----Original Message-----
Sent: Saturday, December 05, 2009 9:43 PM
To: Szalata, Zenon M.; Eric Norum
Are you using the asyn record?  If so, then do a
dbpr "myAsynRecord" 5
to see what you have set the EOS string to.
From: [email protected] on behalf of Szalata, Zenon M.
Sent: Sat 12/5/2009 11:38 PM
To: Eric Norum
I am not aware of explicitly specifying the EOS string.  I thought that
EOS string was not used and only the EOI was.  That is, the KS3988 GPIB
CAMAC crate controller does not require nor accepts an EOS string.  I
maybe wrong on this.  Perhaps, somehow unwittingly I am sending some EOS
string?  How can I verify that?
Actually, in my original message I told a lie, I am not using
streamdevice, just asyn.
Why does it work with asyn R4.9 and not with the newer versions?  Is it
possible that starting with R4.10 default behavior changed?  Could it
be, that starting with R4.10 I have to explicitly say no EOS?
Zen
Sent: Saturday, December 05, 2009 9:01 PM
Subject: Re: asyn R4.10, R4.11, R4.12
The E5810A allows only a single EOS character.  Are you trying to use a
longer end-of-string?
On Dec 5, 2009, at 8:51 PM, Szalata, Zenon M. wrote:
> Hi Eric,
> I am using Agilent E5810A.
> Here is a line from the st.cmd file:
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> Thank you,
> Zen
> From: Eric Norum [mailto:[email protected]]
> Sent: Saturday, December 05, 2009 8:35 PM
> What GPIB controller are you using?
> On Dec 5, 2009, at 5:42 PM, Szalata, Zenon M. wrote:
>> I have a simple soft IOC which uses asyn and streamdevice.  It does
IO
>> with KS3988 GPIB CAMAC crate controller.  The IOC works correctly
with
>> asyn R4.9.  I have installed asyn R4.12 and my IOC does not work with
>> asyn R4.12.  I get the following message: "EOS TOO LONG".  I also
> tried
>> asyn R4.11 and R4.10 I see the same message with these the two
> versions
>> of asyn as I see with the latest.
>> How do I overcome this difficulty?  Do these newer versions of asyn
>> require that I make some change to my IOC?  Can someone help me with
>> this, please?
>> For now I am forced to stay with asyn R4.9.
>> Thanks,
>> Zen
> Eric Norum
> [email protected]
Eric Norum
[email protected]
? asynOctetBase.patch
Index: asynOctetBase.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/interfaces/asynOctetBase.c,v
retrieving revision 1.17
diff -u -r1.17 asynOctetBase.c
--- asynOctetBase.c	28 May 2008 18:58:53 -0000	1.17
+++ asynOctetBase.c	6 Dec 2009 17:53:02 -0000
@@ -90,11 +90,11 @@
        asynUser *pasynUser,void *registrarPvt);
 static asynStatus setInputEosFail(void *drvPvt,asynUser *pasynUser,
                         const char *eos,int eoslen);
-static asynStatus getInputEosFail(void *drvPvt,asynUser *pasynUser,
+static asynStatus getInputEosDefault(void *drvPvt,asynUser *pasynUser,
                        char *eos, int eossize, int *eoslen);
 static asynStatus setOutputEosFail(void *drvPvt,asynUser *pasynUser,
-static asynStatus getOutputEosFail(void *drvPvt,asynUser *pasynUser,
+static asynStatus getOutputEosDefault(void *drvPvt,asynUser *pasynUser,
 static void initOverride(octetPvt *poctetPvt, asynOctet *pasynOctet)
@@ -116,9 +116,9 @@
     if(pasynOctet->cancelInterruptUser == cancelInterruptUserFail)
         override |=  overrideCancelInterruptUser;
     if(!pasynOctet->setInputEos) pasynOctet->setInputEos = setInputEosFail;
-    if(!pasynOctet->getInputEos) pasynOctet->getInputEos = getInputEosFail;
+    if(!pasynOctet->getInputEos) pasynOctet->getInputEos = getInputEosDefault;
     if(!pasynOctet->setOutputEos) pasynOctet->setOutputEos = setOutputEosFail;
-    if(!pasynOctet->getOutputEos) pasynOctet->getOutputEos = getOutputEosFail;
+    if(!pasynOctet->getOutputEos) pasynOctet->getOutputEos = getOutputEosDefault;
     poctetPvt->override = override;
@@ -406,14 +406,20 @@
 { return showFailure(pasynUser,"setInputEos");}
-{ return showFailure(pasynUser,"getInputEos");}
+    *eoslen = 0;
+    return asynSuccess;
 { return showFailure(pasynUser,"setOutputEos");}
-{ return showFailure(pasynUser,"getOutputEos");}
+    *eoslen = 0;
RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
Re: asyn R4.10, R4.11, R4.12 Eric Norum
RE: asyn R4.10, R4.11, R4.12 Mark Rivers
Prev: RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
Next: RE: asyn R4.10, R4.11, R4.12 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
